Old 12-11-2006, 10:43 AM   #1 (permalink)
atin's Avatar
Angry Help needed again!!!!!!!
my comp is crap .im thinking of gettin a new one,now my keyboard has started behaving wierdly.some buttons just dont work,like the down arrow,i cant apply brake in NFS,there are many other keys showing same behaviour,i cleaned it but to no avail.
The ladder of success is never crowded at top:Napolean
atin is offline
Old 12-11-2006, 10:52 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Help needed again!!!!!!!
Is this issue with NFS alone? Which Keyboard are you using?
Kiran Kumar R
Kiran.dks is offline
Old 12-11-2006, 11:01 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
Try cleaning the PS2 port, both in M/B & the Keyboard's.
& you can REASSIGN the KEY for Brake, like you can reassign the "Brake" (Down-arrow) key to "M".
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 12-11-2006, 11:17 AM   #4 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
u r k/b must be old buy a new k/b how much it cost mere rs 900/-
it will work fine
OR
try reinstalling the drivers there was a virus in my comp that controlls my mouse!!!!!!! and make my webcam not work !!funny na
so check through antivirus s/w
If the problem still exist try cleaning it by a method by alcohol
OK
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 12-11-2006, 11:19 AM   #5 (permalink)
Laptoping
Sourabh's Avatar
It is not a problem with the keyboard. It is an old bug within the game. There was a similar issue with turning left/right on Nitroboost (forgot the name for it UG2 )If you assign some other key for direction change and it still doesnt work, in all probability its that bug. I know of it coz a friend of mine complained the same. I don't know if they have fixed this but getting the latest update for your NFS game version, should solve the problem.
Sourabh is offline
Old 12-11-2006, 12:26 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
& If the keyboard is the problem then you can go for SAMSUNG Keyboard. It just costs around Rs.200 /-.
Old 13-11-2006, 10:31 AM   #7 (permalink)
atin's Avatar
No the prob is not with game the buttons do not work at all,even in notepad or any other app.
my keyboard is logitech and merely 1 yr old.
do i have to buy a new keyboard since really my keyboard is a good one except 4 this minor prob
PS:to S18000rpm ofcourse i knew i can change the button 4 brake.
atin is offline
Old 13-11-2006, 10:46 AM   #8 (permalink)
Welcome To The Jungle
sysfilez's Avatar
get ur k/b replaced if its under warranty.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 13-11-2006, 11:52 AM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
@atin, well dude, the way you addressed your problem, it seemed to me that the problem was only while playing the game.
Anyways, if cleaning the ports didnt help, then get a friends KeyBoard & test whether the Problem is with the Keyboard or the Motherboard Ports.
