Old 11-11-2006, 08:01 PM   #1 (permalink)
doom_marine's Avatar
Default Lcd problems
I'm using a viewsonic vx924 lcd monitor. The problem is that i just shifted my house and when i assembled my system together and ran the system the monitor started giving problems.
the system was running fine when suddenly the display when blank and then it appears again and them blank again i could still see my desktop appear and disappear. That is the display keeps going and coming and the power indication light on the monitor keeps blinking too. When i switched off the monitor and system and plugged the monitor somewhere else without the system the same flickering started and the power indicator still kept on blinking thought there was no display since no computer.
could someone help me by telling me how to solve the problem or could someone give me a contact number of viewsonic people for service. Preferably in madras.
thank
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
doom_marine is offline
Old 11-11-2006, 08:46 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Lcd problems
May be there is some loose connection?
Tech Geek is offline
Old 11-11-2006, 11:11 PM   #3 (permalink)
assasin's Avatar
Try using a diff power cord.
assasin is offline
Old 12-11-2006, 12:12 PM   #4 (permalink)
I checked for loose connections and also changed the power cable still no change. The switching on and off takes place at a fixed time period hence i don't think thats the problem.
AMD Athlon X2 4200+
2GB DDR 400 RAM
Old 12-11-2006, 01:41 PM   #5 (permalink)
Seems it is time to ask for replacement. It seems scary since I also bought a VX922. Anyways, the warranty is there for three years.
V.Prem Kumar
janitha is offline
