* A dual core processor (of lowest price)
* 1 GB RAM
* A motherboard
He is not a serious gamer...so onboard graphics will be enough.In the case of dual core processors which is better AMD or INTEL and which is cheaper?
Please tell me their price also....
ThnX in advance....
Anil wats his budget??widout budget it will b next imposible to suggest.Any day C2D is betta then X2 at this point of time...Cheapest is AMD AM2 X2 3600+ for 6-6.5k...i wud suggest Core 2 Duo E6300=8.7 wid intel 965RY wid X3000 onboard grapix which is quite decent...AM2 X2 3800+ for 8.5 which i dun think is worth buying as u can get C2D for that much.choice is urs...and dun forget to tell us bout ur budget so that v can suggest the rite ram,mobo, and eva proccy.bye tc
My Frnd assasin u hav suggested MSI 965 NEO which dont have onboard gpu and as u can c Anil want a mobo with onboard gpu...so i dont think he will b going for NEO widout onboard Grapix.
