Old 11-11-2006, 08:26 AM   #1 (permalink)
ECE0105's Avatar
Question P4 2.8 (511) Prescott Temp. and Upgrade.
Hi,
I have a P4 2.8 (511) Prescott with an Intel D101GGc Motherboard.
I happened to see a lot of Dust on the Heatsink Assembly of the processor. I removed it and cleaned it using a Brush....
After putting it back in, I checked the temperature in the BIOS and find that it is 62degrees C.
Is it Normal, or should I clean the processor and put some more paste on it. Please lemme know the correct procedure to do it and can I also put the paste on my RAM, (Just for the heck of it)... Cos, I don't use ACs and the my Cabinet has only two small Fans, on the side panel, just above the processor.
Also, would it be worthwhile to upgrade to a Pentium D processor, the highest which I believe is the 950 with 3.40 GHz and 800 MHz FSB. Or the P4 D-820, cos this retails for around 5,000 in Hyderabad.
My Motherboard Revision is AAD35788-309
What would be the estimated cost of upgrading Only the Processor, I have a PC32000 512MB RAM(Running in Single Channel).
I am not looking at a full upgrade, since I have bought this rig in April this year and Do not wish to spend much, but I still feel that the computer runs quite slow.
ECE0105 is offline
Old 11-11-2006, 08:48 AM   #2 (permalink)
assasin's Avatar
Default Re: P4 2.8 (511) Prescott Temp. and Upgrade.
The temp is quite normal.if u wanna upgrade den buy Pentium D 950 but it wont do u much good.Jst wait 4 few more mnths & upgrade to C2D.
assasin is offline
Old 11-11-2006, 09:21 AM   #3 (permalink)
ECE0105's Avatar
Thanks for the response, could u lemme know how much my present Rig could go for and the best config that I can buy after spending a max of 10k...
ECE0105 is offline
Old 11-11-2006, 09:52 AM   #4 (permalink)
assasin's Avatar
Dont sell ur whole rig,just sell the proccy + mobo + RAM.For dat u'll get a max of Rs6000.
C2D E6300 = Rs.9200
Intel D965RY = Rs.6800 or Asus P5B DLX = Rs.11000
Ram: 512 = Rs.3200 & 1GB = Rs5800
AMD Athlon X2 3800+ & Asus M2N-MX = Rs.12600.
If u cant buy the C2D config,u can buy the AMD.It'll give u far better performance dan ur present rig.
assasin is offline
Old 11-11-2006, 10:21 AM   #5 (permalink)
ECE0105's Avatar
Woah !!!!!!
This is way outta my budget. I guess I can go for the AMD, but Will my RAM suffice, cos the prices of RAM are increasing by the day....
Last week, I find the price of Hynix 512 MB (PC3200) for 2,900.
ECE0105 is offline
Old 11-11-2006, 11:07 AM   #6 (permalink)
samrulez's Avatar
Dood the temp is not normal.....62 IDle!!!!....Man it should be 62-65 @full load........Your processor must be touching 80 at load....
Sam :D Rulez :lol:
samrulez is offline
Old 11-11-2006, 11:47 AM   #7 (permalink)
assasin's Avatar
A Prescott doing 62 C at idle is not dat bad.My previous rig (Pentium D) used to idle at 60 -64 C.
@ECE0105 Even if u buy AMD u'll hav to buy new ram cuz u'll need DDR2 ram
assasin is offline
Old 11-11-2006, 06:35 PM   #8 (permalink)
ECE0105's Avatar
I think the temp thing got fixed....
Just checked and it is idling at around 57 deg. Which I hope is fine.
@ assasin, cud u lemme know which is the fastest DDR2 RAM avl. in the market...
ECE0105 is offline
Old 11-11-2006, 09:12 PM   #9 (permalink)
samrulez's Avatar
@ assasin : Dood, the pentium D has 2 Prescotts glued to gether....It can even take 80degs....Smithfeild...core understand...
For Prescott.....65 at load is recommended....
Cellshock...1GHz @4-4-4 !!!! ..2GB kit costs 25k...I think..
Sam :D Rulez :lol:
samrulez is offline
