Old 10-11-2006, 09:49 AM   #1 (permalink)
ArZuNeOs's Avatar
Default .:Disk Read Error:.-but works on other COM-Wat problem
my main sys
P4 3.02 ghz
intel 915gavl mobo
512 DDR 400 Mhz Corsair
samsung 120 Sata HDD
WIN Xp Pro SP2
My other sys
D930 ,
D945 Gnt mobo
1 gb DDR2 Trans
Seagate 300Gb sata
Win XP Pro Sp2 & Win Server 2000
Now the problem
My 1st sys's HDD failed Throwing up the error....I used Ultimate boot CD & it showed no HDD devices & da same in BIOS
But when i connected it along with my 300 gb It showed properly ....i loaded win server & was able to view contents for sometime
I also loaded win Server in da old HDD &
tried to use it along wid the 1st sys
But failure ...it showed the same msg
Wat do i do now
Do i have to throw the HDD to the samsung repair center (in chennai....which place) or is there a way out
Ur Experience is asked 4
Back to the world of realms
ArZuNeOs is offline
Old 10-11-2006, 05:14 PM   #2 (permalink)
assasin's Avatar
Default Re: .:Disk Read Error:.-but works on other COM-Wat problem
Connect only the 120GB hdd in the new sys and 300GB in ur old sys and see if dere detected.If the 120Gb is not detected den get it replaced/serviced by Samsung.
assasin is offline
