Old 09-11-2006, 10:10 AM   #1 (permalink)
Smile processor and mobo.
hello .....
i would like to upgrade my pc plz telll me processor and mobo combination with in rs.11500 whether amd or intel but processor must be dualcore.
nishant872 is offline
Old 09-11-2006, 10:22 AM   #2 (permalink)
assasin's Avatar
Default Re: processor and mobo.
INTEL - Either buy a C2D E6300 + Gigabyte 945 chipset mobo,or C2D E6300 + Intel 946 mobo.
AMD - AMD Athlon X2 3600+ & Asus M2N-MX or AMD Athlon X2 3600+ and Asus M2N-MX.
__________
INTEL - C2D E6300 + Gigabyte 945 chipset mobo or C2D E6300 + Intel 946 mobo.But the above config will exceed ur budget by rs2500 - 3000.Dont buy Pentium D.
AMD - Athlon X2 3600+ & Asus M2N-MX.This will be i ur budget.
Athlon X2 3800+ & Asus M2N-MX.This will exceed ur budget by 1000 bucks,but buy it if u can afford it.
assasin is offline
Old 09-11-2006, 08:46 PM   #3 (permalink)
which is better a c2d e6300 or the athlon 3800?????
primitive_trash is offline
Old 09-11-2006, 08:58 PM   #4 (permalink)
assasin's Avatar
C2D E6300 will surely be better dan Athlon X2 3800+.Get a Asus P5B DLX or Intel 965RY mobo if u buy C2D.Else go for Athlon X2 3800+.
assasin is offline
Old 12-11-2006, 02:27 PM   #5 (permalink)
wht abt m2n pv vm of asus for amd
