Old 08-11-2006, 11:56 PM   #1 (permalink)
Panchu's Avatar
Question Seagate SATA crashed....Recovery needed!!!!
Guys.....
I got myself a 120 GB Seagate Baraccuda SATA some weeks back....I copied all the data from my old HDD to the SATA and formatted my old drives....Recently I had a lightning exposure on my PC....I took my HDD to some friends' and checked it....It worked just fine....So I made sure it was OK...Just somedays back I got a new motherboard and connected my SATA to it...First it worked fine....I loaded Windows and all and suddenly it turned off....Now whenever I connect the drive to the PC, the motherboard stops working...I am facing the same problem with other computers to....Hav any of u ppl heard of something like this???? Is there any way I can recover data from the HDD????
Plz reply fast.....
Real fast!!!!!!!!!!!!!!!!!!!!11
Panchu is offline
Old 09-11-2006, 12:50 AM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: Seagate SATA crashed....Recovery needed!!!!
if u still have ur old HDD than install that HDD in ur PC
now downlaod a recovery software n install in it
i'll suggest to download
Ontrack data recovery software from www.ontrack.com
for more info visit this thread
data recovery from hdd
satyamy is offline
Old 09-11-2006, 11:38 PM   #3 (permalink)
Panchu's Avatar
guys......I did mention........THE PC DOESNT TURN ON WHEN I CONNECT THE HDD!!!!!!!!!!!!!!
Panchu is offline
Old 09-11-2006, 11:43 PM   #4 (permalink)
assasin's Avatar
Does ur mobo has SATA hot plug support?If yes den plug in ur hdd after booting into windows & see if its detected.
assasin is offline
