Old 08-11-2006, 09:56 PM   #1 (permalink)
It's me.....
Matrix's Avatar
Smile Please Help : Over Motherboard and Processore
Hello everyone,
I am going to buy a PC in which i want a Pentium D processore ( 2.80GHz , 4MB L2 cache ) with intel D945GCL motherboard ( Intel 945G chipset ).
I want to know is which boards will better for me between intel 945 or intel 946 . As i think this processore will not work on 915 boards...
Please suggest me ...
Matrix is offline
Old 08-11-2006, 11:24 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Please Help : Over Motherboard and Processore
well if u ask me.. personally would say neither board... rather GO for the D102GGC...
ATI Chip set makes a lot of diffrence while running Vista (though D102GGC is not a idle board but still i have tested and found Vista worked better on that board...)
also D102GGC has 2 PATA Port... where 945GCL only 1... otherways all other feature set is almost same...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-11-2006, 09:27 AM   #3 (permalink)
assasin's Avatar
Go for intel 946 or Intel 965 boards as they will give u d option of upgrading to C2D if u want.
assasin is offline
