Same problem was occuring when I used my HP PSC 1410 for either scanning or printing. But I could find the reason for it, that is a Trojan Horse in my computer. But I repeatedly scanned my computer with Avast Antivirus 4.7 with latest updates but couldn't find any virus or trojan horse.
The handycam was purchased one month ago. It is not defective and it works on my friend's laptop. It is under warranty.
Try scanning with BitDefender AV (on-demand scanner) in safe mode.
for the Printer, goto HP website & download updates for the Printer Drivers.
go here for Printer Problem, select "Softwares & Drivers Download"-> your OS"
i also have the same Printer & had problems in Printing word documents which had graphics (picture) in it, but a simple driver update solved the problm.
ASUS K53SV SX520D + BF3
u can try someothere
antivirus like norton and mcfee but for yr
u must scan with those antivirus.. and then see if there were a
same problem..also check for antispyware..
Be like a postage stamp-stick to one thing until you get there.
Windows Xp Professional
__________
Second hand machine don't have motherboard model
__________
I have tried norton, quickheal, mcaffe, none could solve the printer's problem. Only avast could detect the virus.
From my past experience of a friend facing same problem unable to plugin any usb device, it was found that his xp pro "copy" was having a problem he formatted than HDD & got the problem solved when he installed XP pro from another disk.
He use to get BSOD the moment he connected any usb device, he too tried every thing but nothing worked.
ur problem may be with ur hardware!!! I don't know but may work this one.
u have to clean ur slots or ur crads in cpu. it may work bcs i have face one kind of prob. with my modem when i opened my cpu cabinate i found i sours inside fixed between modem & graphoc card !!!!!!!!!!!!!!!!
