Old 07-11-2006, 02:55 PM   #1 (permalink)
Default Issues with power supply for Intel 965RY...
I bot the Zebronics (also tried with Priya brand) power supply. When I switch on the button of the UPS, there is a fraction of power supply which gets passed to my CPU, and because of which the CPU gets switched on for 2 seconds and then gets switched off. Then as usual i switch on the power button on my CPU to start my system. Just wanted to check if this is abnormal with 965RY... Since my system is up and running smoothly i dont want to make any changes to it. Please let me know your valuable suggestions on this.
Thanks
Dev
Intel Core 2 Duo E6300, Intel DG965RY, Transcend 1 GB 533, Seagate 200 GB 7200.10 SATA II
Innovator is offline
Old 07-11-2006, 02:57 PM   #2 (permalink)
varkey's Avatar
Default Re: Issues with power supply for Intel 965RY...
i have the exactly the same situation. btw my motherboard is a dg965wh.
anyway i think its normal for it to act like that.
experts pls confirm.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 07-11-2006, 11:20 PM   #3 (permalink)
Good to hear u have DG965WH, actually i was planning for it but wasn't available in hyd so went for RY. btw, howz the sound clarity on ur board... i feel in my board the volume is low...
Old 04-04-2008, 03:57 PM   #4 (permalink)
I had this problem... change the ACPI mode in the BIOS... aftre that i am not facing this issue...
motorhead_biker is offline
Old 04-04-2008, 11:44 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Yes, this is for all DG965 boards. I have DG965RYCK and i solved it by changing the ACPI mode too.
dheeraj_kumar is offline
