Your reply is pretty confusing....make a habbit to use a pause with fullstop or comma..
lets go line by line
Ok Do U Have Seen The Five Pin Two Up With Gap And Three Down
Yes its like this ---->
Connect The Brush Wire To The Upper Pin And The Coated Wire To The Down Pin.
Now what is a brush wire & coated wire ....
Do U Have A Dvd Connector Wire To Tv The Pin Of It ---- Is The Coated And ) The Surrounding Pin Is Brush
Now what do you mean by DVD connector wire ???
Change The Setting From Bios In Nb Settings Choose Tv Only And Then Save It And Restart It It Will Definately Start And U Have To Also Set Ur Catalyst Driver And Disable Ur Monitor First And Select The Tv Ok. (***** The Left Pins Are Only Use For Black And White Picture Ok ******)
Only thing i understood is this
Sorry but can you reply once again
I did bit of googling and only thing i found is this
http://www.techtalkz.com/processors-...-vm-board.html
Thanks
