Old 06-11-2006, 12:34 PM   #1 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Grrr Grrr Grrr
ya thats the fan noise i get after some time i start my pc.
many will suggest speed fan...and yes i have that one...then when the sound starts i have to start speed fan....and take the speed of fan to 80% to control the speed..although i have noticed that the temperature is okay....
when i start game again the noise starts..although its still at 80% speed....then i have to lower it to 70%........
now sometimes i do not start the speed fan but slap my cabinet few times and the noise goes .....
Now can anybody suggest how can i get rid of this problem permanently
P.S.- one of my cabinet side is aways open ..so no problem of heating.
wizrulz is offline
Old 06-11-2006, 01:00 PM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: Grrr Grrr Grrr
exactly the same prob faced with me and i had to slap it more than once to fix it. never been able to detect wats vibrating it so much. thou i dont play games and all.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 06-11-2006, 01:09 PM   #3 (permalink)
Come get Some
DukeNukem's Avatar
tighten up every nuts and bolts of your cabi, smps. coz' its the viberation that is causing the grrrrrrrrrrrrrrrrrrr sound
stop slapping your computer. after all s/he is your best friend who need your tender care to survive in this cruel world( of yours), and has feelings too. always try to impress and make her/him look good with new accessories. get the point.
else skynet will get u first before john corner
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 06-11-2006, 05:34 PM   #4 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Happened with me once ..turned out that the smps fan is not able to move properly due to dust accumulation.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 06-11-2006, 07:12 PM   #5 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
either ur fan's axil has got lots of grease and dust or something is loose/touching the fan or the mobo...
also mostly the fan has a sticker on one side to close off the rotating part to get dry or dirty.. see if that is loose or absent.
Rollercoaster is offline
Old 06-11-2006, 11:08 PM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
cannot be smps fan for sure...as i when i lower fan speed of proc....the sound goes.....
wizrulz is offline
Old 06-11-2006, 11:45 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
My PC also faces same prob, just do one thing remove it completely & clean it............
satyamy is offline
Old 07-11-2006, 12:39 AM   #8 (permalink)
The Devil's Advocate
iMav's Avatar
http://beingmanan.com
iMav is offline
Old 07-11-2006, 01:00 AM   #9 (permalink)
bang bang!
Chirag's Avatar
Happened with me long time back. It was bcoz of dust. I cleaned it and then the noise stopped. But after a week it started again. I used to do that after each week untill I got new pc.
Chirag is online now
Old 07-11-2006, 07:30 AM   #10 (permalink)
WOW... are you?
gsoul2soul's Avatar
Mine sounds like a "Scotty"... and during night time, it's like... "Hello mom... Hello everybody in home... I'm using PC"
Humph... not a Secret anymore !!!
He he he... anyways, to check... I used my fingers to Stop the fan of both CPU and my AGP card (lol, only for a second)
And found it's not them... rather my NEW PSU (with 3 fans)... is that that humming bumble bee !!!
any suggestion?
gsoul2soul is offline
