Old 06-11-2006, 07:59 AM   #1 (permalink)
Unhappy system rebooting
Hi guys i am facing one problem. I have dual operating system in my system. In the first partition there is windows 98. in the second partition there is windows XP. Now the problem is that after switching on my system i will get the option to select whether windows XP or windows 98. When i select any of these the system gets reboot without showing anything. where is the problem? Is it in hard disk or in the software that i have. Both the windows are geniune. Please help me.
sharad_mlk is offline
Old 06-11-2006, 08:47 AM   #2 (permalink)
assasin's Avatar
Default Re: system rebooting
It cud be dat the MBR(Master Boot Record) has become corrupted.Try to recover the MBR.
assasin is offline
Old 06-11-2006, 12:25 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
can u boot in safe mode (press f8 at startup)....????
wizrulz is offline
Old 06-11-2006, 01:30 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Boot using Windows XP Setup CD and enter into Recovery Console, and then give following commands:
fixmbr
fixboot
bootcfg /rebuild
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-11-2006, 02:17 PM   #5 (permalink)
it is not booting in the safe mode also when i boot the OS in safe mode. It will display all the file but after that it just stuck on mup.sys and the pc gets restarted again. I had tried one other option don't restart automatically that appears after pressing F8 key but it's of no use. it displays the blue screen which contains some serious error i don't know what it is.
