Old 05-11-2006, 06:16 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Smile Suggestion on mobo neede
Please lemme know whether INTEL D102GGC2 mobo is good enough for Intel Pentium D 915 2.8ghz,800mhz,2x2mb l2 cache......
Please help me out....
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 05-11-2006, 06:54 PM   #2 (permalink)
assasin's Avatar
Default Re: Suggestion on mobo neede
Buy Intel 965 chipset based mobo as u'll have d option to upgrade to C2D later.If u want it cheap buy Intel D945GNTL.Dont buy Pentium D.They r crap,buy AMD or C2D
assasin is offline
Old 05-11-2006, 08:50 PM   #3 (permalink)
Why do u call Pentium D crap?
Sony Vaio CW26FG
Old 05-11-2006, 09:07 PM   #4 (permalink)
Gaurav's Avatar
ya, assasin,,, why do you call pentium D crap???????????????
Gaurav is offline
Old 05-11-2006, 09:44 PM   #5 (permalink)
assasin's Avatar
Pentium D (Also Pentium 4 Prescot ) r all crap cuz they have a very high TDP rating and generate a lot of heat.Even the lowest AMD Athlon X2 beats the Pentium EE on most benchmarks.If u wanna buy Intel buy C2D else buy AMD.The gate oxidising temp of Intel is also lower than dat of AMD.u wont be able to OC a P D or P4 too high wit stock cooling.For these & lots of other reasons i call Pentium D CRAP.
assasin is offline
Old 05-11-2006, 09:48 PM   #6 (permalink)
Gaurav's Avatar
thanks for d info, i was about to buy that one (pentium D 920) but now i won't
Gaurav is offline
Old 05-11-2006, 10:07 PM   #7 (permalink)
But if we consider only performance(w/o oc) then can we still call pentium D crap?
Sony Vaio CW26FG
Old 05-11-2006, 11:13 PM   #8 (permalink)
assasin's Avatar
Dude why dont u search 4 performance reviews on the net.Den i think u'll agree with me.
assasin is offline
Old 06-11-2006, 12:06 AM   #9 (permalink)
please gimme some website which compare processors
Sony Vaio CW26FG
Old 06-11-2006, 12:38 AM   #10 (permalink)
assasin's Avatar
Just google this yaar 'Intel Pentium D + AMD Athlon X2'.
assasin is offline
