Old 04-11-2006, 08:17 PM   #1 (permalink)
Default Help
I own a laptop and the OS is in C drive.
my total consumption of disk space is 5 gb
but when I right click in properties it shows 8 gb.
can any one explain the phenomenon
ritish is offline
Old 04-11-2006, 08:27 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Help
It happened to me also many times
I didn't care about it since i had a lot of space on my PC
Tech Geek is offline
Old 04-11-2006, 09:17 PM   #3 (permalink)
assasin's Avatar
Default Re: Help
The 'missing space' is allocated for system use.for details just view the post:
missing bytes
assasin is offline
Old 04-11-2006, 11:03 PM   #4 (permalink)
Default Re: Help
but 3gb space is too much to be used by other resources.
ritish is offline
Old 05-11-2006, 12:42 AM   #5 (permalink)
assasin's Avatar
Default Re: Help
To see d amt of space of ur allocated to Page File just type 'dxdiag' in run.u'll get ur answer.For my pc its bout 2.4GB
assasin is offline
Old 06-11-2006, 01:23 PM   #6 (permalink)
Default Re: Help
my page file is only 476mb. still i can account for the rest 2.5GB.
What should I do next to correct it .
Is there any software available for recovering from such inconsistencies
ritish is offline
Old 06-11-2006, 02:42 PM   #7 (permalink)
assasin's Avatar
Default Re: Help
I dont think dat u'll get any software to reclaim dat space.U jst hav to live wit it.
assasin is offline
