Old 04-11-2006, 06:24 PM   #1 (permalink)
lalu's Avatar
Default something wrong with my monitor
Iam using 17" crt monitor today evening onwards it showing a problem that the whole screen had become yellowish in colour. if anyone know whats the problem please help. i had deggissed it but no use.
lalu is offline
Old 04-11-2006, 06:45 PM   #2 (permalink)
Default Re: something wrong with my monitor
you must have changed the color temperature setting from default 9300 (bluish) to 6500 (yellowish)
Check the color settings in the menu & report back.
ranjan2001 is offline
Old 04-11-2006, 06:54 PM   #3 (permalink)
lalu's Avatar
i had not done anything. i was chatting with my bro's suddenly the colour changed!
lalu is offline
Old 04-11-2006, 07:00 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
if you have a "Default Settings" selection, then select it thru the Monitor Menu. & try to change the Temperature Settings yourself.
ASUS K53SV SX520D + BF3
s18000rpm is online now
