Old 04-11-2006, 11:49 AM   #1 (permalink)
Question Any suggestion On buying Home PC for gameing
Hai everyone,
I want to buy a new home pc for both gameing as well as for running software tools so if any one of you can suggest some pc within 25K to 30K it would be vey helpful.
dilpedilip is offline
Old 04-11-2006, 02:12 PM   #2 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Default Re: Any suggestion On buying Home PC for gameing
Buy a PC with 945 chipset. Its in your budget and had great upgrade option.
Or wait few months if you want a vista ready pc.
Quiz_Master is offline
Old 04-11-2006, 02:23 PM   #3 (permalink)
jz2linkinpark's Avatar
you can probably get a c2d comp for that much or if you increase by a few more thousand
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 04-11-2006, 03:01 PM   #4 (permalink)
assasin's Avatar
U'll easily get a PC wit AMD dual core proccy in ur budget.
assasin is offline
