Old 04-11-2006, 11:00 AM   #1 (permalink)
Default thermal compound.....
wud applying new thermal compound reduce the temperature greatly ...??
i am havin temp issues with ma card and had posted it earlier.....
am planning to get some thermal compoud........
my 6800gs goes upto around 90 when playin games.........
anilthomas26 is offline
Old 04-11-2006, 11:07 AM   #2 (permalink)
samrulez's Avatar
Default Re: thermal compound.....
yeah! Applying thermal paste reduces the temps by almost 10 degs......
Get a AS5 or something...remove the stock HSF and apply it on the core...and put it back together..
Sam :D Rulez :lol:
samrulez is offline
Old 04-11-2006, 12:59 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Sure dude n do what SAM has suggested. But do clean the core surface before applying the thermal paste.
john_the_ultimate is offline
Old 04-11-2006, 04:44 PM   #4 (permalink)
how do i clean the core ???...
cleaning the heatsink wud be easy...but how do i clean the core ??
__________
so..that makes the temp go down to 80...maybe 75...but that aint good right ???
when i play halflife 2 episode 1 at max settings....i mean the max recommended for a card (which includes antialising 2x).......there is no much prob....except for certain explosion........during these explosions i can c chess boards...
Last edited by anilthomas26; 04-11-2006 at 04:44 PM. Reason: Automerged Doublepost
Old 04-11-2006, 04:58 PM   #5 (permalink)
samrulez's Avatar
Well 75 for a 6800GS is good enough!......what do you want 42????...
Well removing the Heatsink is very easy just be careful.
First remove the HSF and clean the Core with a piece of cotton and remove the existing thermal paste then apply a thin,even layer of AS5 or any other Th. Paste...
Sam :D Rulez :lol:
samrulez is offline
Old 04-11-2006, 06:19 PM   #6 (permalink)
so.....75 aint that high a temp.....?????
well then...,maybe the thermal comp shud do.....
lemme try it....
my ambient temp is around 60....
Old 04-11-2006, 10:45 PM   #7 (permalink)
lemme try it....
Fahrenheit?
V.Prem Kumar
janitha is offline
Old 05-11-2006, 12:58 AM   #8 (permalink)
No pain....No gain
You could use lint free cloth and nail polish remover to clean the core surface.
Old 05-11-2006, 07:25 AM   #9 (permalink)
Generally it is advised to use "lint free" cloth and Isopropyl Alcohol for the cleaning.
V.Prem Kumar
janitha is offline
Old 05-11-2006, 03:30 PM   #10 (permalink)
lint free ????
wats that supposed to mean ???.....
and which cleaning solution shud i use......isopropyl alcohol might be a gud solution but wher do i get it from ??????.....
Old 05-11-2006, 04:59 PM   #11 (permalink)
samrulez's Avatar
Soft cloth , the fiber in these cloths doesn't shed! ...LOL....
Sam :D Rulez :lol:
samrulez is offline
Old 05-11-2006, 05:27 PM   #12 (permalink)
Eazy's Avatar
Follow instuctions on how to Apply AS5 on this page...
http://www.arcticsilver.com/arctic_s...structions.htm
the cleaning instructions on these pages will be the same for any type of Heat Sink compound. Get good quality Acetone and IsoPropyl Alcohol - any impurities in these solutions can cause loss of heat transmission. Dont use Nail Polish Remover instead of Acetone as it contains some additive perfumes and oils which create a barrier to heat transmission.
A lint free cloth will be any clean old discarded vest which has been washed often.
Eazy is offline
Old 05-11-2006, 05:33 PM   #13 (permalink)
Isopropyl alcohol is available at any of the lab suppliers and is not costly.
V.Prem Kumar
janitha is offline
