Old 03-11-2006, 08:59 PM   #1 (permalink)
ArZuNeOs's Avatar
Default Formatting Prob
Guys this may sound silly...But I am confused & Afraid
My Hdd has 5 partitions
total 120 GB
C: 10 gb NTFS where core of windows
D: 10 GB NTFS Where program Files
E: 30 GB FAT 32 Where backup of my office files (12.08 GB used)
F: 30 GB FAT32 Songs Wallpapers & Softwares (8.06 GB used)
G: 40 GB NTFS Movies & Cds & Backup (28.56 GB used)
Now the scandisk always runs when i start Windows Xp Pro
So I decided to do the following With Ur Help
1) Can I delete the old partition table Without loss of data & reallocate them with 5,10,100 gb all NTFS Or
2) Atleast take care of FAT 32 to NTFS & Join them
..in other words convert E & F to ntfs & create E as 60 GB again Without loss of Data
3) Can i be able to do the formatting stuff Using the other computer & through Windows
Is the above possible ?????
Reply soon guys
Back to the world of realms
ArZuNeOs is offline
Old 03-11-2006, 09:09 PM   #2 (permalink)
assasin's Avatar
Default Re: Formatting Prob
Try Partition Magic 8.It'll solve most of ur probs but u'll loose data if u delete the old partition table.
assasin is offline
Old 03-11-2006, 09:19 PM   #3 (permalink)
Resident Fanatic
Manshahia's Avatar
Y dont u buy a DVD writer and take backup of everything. It wud take around 5 or 6 DVD's using 8gb per DVD and then format the whole drive, do the partitions again.
Manshahia is offline
Old 03-11-2006, 11:35 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
>>>There will be loss of data
>>>U can convert both FAT32 to NTFS w/o loss of data ...but cannot join them as it will agian mean deleting old partition....
>>formatting can be done thru other comp whenu connect ur HDD to it
[/QUOTE]
wizrulz is offline
Old 04-11-2006, 12:25 AM   #5 (permalink)
assasin's Avatar
Wizrulz u can join 2 HDD patitions without any loss of data.Parititon Magic 8 does dat trick.
assasin is offline
Old 04-11-2006, 01:11 AM   #6 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
partition magic demo version is useless. any freeware alternative???
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 04-11-2006, 08:05 AM   #7 (permalink)
gooby pls
Third Eye's Avatar
@neogopo: First back your E and F data to a DVD or Old HDD if you want to combine them.
Third Eye is online now
Old 04-11-2006, 12:17 PM   #8 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
If that did it for u then i guess lucky one...or had a lucky day.....most members will agree that its not 100% that it will not give loss of data...so taking a backup is adviced
wizrulz is offline
