Old 03-11-2006, 08:39 PM   #1 (permalink)
assasin's Avatar
Unhappy Access is Denied!
My pc was working fine when all of a sudden i'm not able to access 2 of my HDD prompts(I've six and D: & G: r not accessible).Whenever i try to access them from Win Explorer i get "Access Is Denied".I can access the prompts from <Ctrl Panel - Administrative Tools - Computer Management - Disk Management>.I've scaned for virus but dere arent any.How shall i be able to open my prompts from Win Explorer.Plz Help Me.
assasin is offline
Old 03-11-2006, 11:42 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Access is Denied!
Which Os???
NTFS or FAT32???
can u see the sharing, security tab in the property window of that drive. ???
wizrulz is offline
Old 04-11-2006, 12:19 AM   #3 (permalink)
assasin's Avatar
OS - Windows XP MCE 2005
NTFS
Yeah I can see sharing tab in the property of that drive
assasin is offline
Old 04-11-2006, 12:53 AM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Pls read following thread:
giving limit to each user in my pc..
And read my posts, may be it'll help U
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 04-11-2006, 08:46 AM   #5 (permalink)
assasin's Avatar
Hey Vishal i;m d loneuser ofmy PC and i didnt do any such NOVIEWONDRIVE stuff.Still i checked it & dere was no 'NOVIEWONDRIVE' dword.Now wat sud i do.
assasin is offline
Old 04-11-2006, 12:14 PM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
NTFS
Try this. Use the file I have attached, save it to your computer and extract it to your d:\
Go to a command prompt and type
takeown D:\(insert name of folder)
Similarly for G:....
This "should" give your current user rights to the folder. Your best doing this with your administrator account.
Hope this works.
Abt .exe, it won't do anything with your hdd, it only change permissions in order you can have access to you hdd.
GIVE UR FEEDBACK
wizrulz is offline
Old 04-11-2006, 12:28 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
see if this helps :
right click the drive, go to sharing and security and enable sharing with full permission.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-11-2006, 02:59 PM   #8 (permalink)
assasin's Avatar
Followed ur instructions Wizrulz.After executing d cmd i got d msg:"Successful,Protection Removed".But the prob is still dere.Cud it be a prob with my HDD i.e a hardware prob????????
assasin is offline
Old 04-11-2006, 03:40 PM   #9 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
For both drives same problem????
surprising.....if the data is not so imp and u have backup then best option is ...1st converting to FAT 32 and then back to NTFS .....
have u checked for bad sectors????
wizrulz is offline
Old 04-11-2006, 04:46 PM   #10 (permalink)
assasin's Avatar
just formatted d drives outright after taking bakup.Now dey r jst workin fine no probs.Lots of THANX toall u ppl.
assasin is offline
