Old 03-11-2006, 06:23 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Core2duo or AMD 3500+
Wat will be the performance difference i will get (in gaming) and general applications if i use Intel E 6300 1.86 GHz processor instead of AMD 3500+
please post your suggestions and give an ideal mobo for intel core2duo
codename_romeo is offline
Old 03-11-2006, 06:40 PM   #2 (permalink)
Default Re: Core2duo or AMD 3500+
6300 + asusP5B deluxe mobo +2gb of corsair ram when over clocked from 1.86 to 3.0GHz will leave behind all amd.
You have further choice too 6400/6600 & top of ther line 6800 alos comming.
ranjan2001 is offline
Old 03-11-2006, 06:51 PM   #3 (permalink)
jamyang312's Avatar
come'on man,,, core 2 duo all the way,,,, even if its not overclocked it still beats amd.....
think u will never see the devil?
look in the mirror and u will see one!
jamyang312 is offline
Old 03-11-2006, 07:08 PM   #4 (permalink)
Tech Geek's Avatar
Of course u shud go for C2D
Tech Geek is offline
Old 03-11-2006, 08:37 PM   #5 (permalink)
1.86 GHz overclocked to 3.0 GHZ its almost double...r u sure we can do that without damaging processor
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 03-11-2006, 08:38 PM   #6 (permalink)
C2D is no doubt better provided you equip with a good enough GPU. Never compromise on the GPU for a CPU in a great majority of cases.
akshayt is offline
Old 03-11-2006, 09:12 PM   #7 (permalink)
Are you comparing an AMD 3500 costing Rs.4500 to the 6800?
V.Prem Kumar
janitha is offline
Old 03-11-2006, 09:14 PM   #8 (permalink)
Indeed yes with well cooled cabinets its a breeze with asus P5B deluxe mobo, see the thread on 2nd page which I posted about overclocking comparision of 6300 vs 6700.
Old 03-11-2006, 09:46 PM   #9 (permalink)
samrulez's Avatar
Dood, that's not possible with the Stock cooler for 24X7 use..
Sam :D Rulez :lol:
samrulez is offline
Old 03-11-2006, 09:57 PM   #10 (permalink)
Quite true thats why I said you need a well cooled cabinet with good airflow.
Reading about overclocking on many other forums these with asus P5B deluxe I understand that you increase the FSB & if the mobo processor cannot boot it resets to the old last boot FSB so the mobo has a feature to protect the processor.
I guess that you wont burn the processor in that case, nevertheless you apply cooling paste with well cooled cabinet & use Corsair TWIN2X2084-6400C4 RAM (DDR2-800 this is a must)
You may want to read about the memory requirements
http://www.xbitlabs.com/articles/mem.../ddr2-800.html
Old 03-11-2006, 11:03 PM   #11 (permalink)
samrulez's Avatar
Well....my friend has the 6300...he also has a mighty TT-BT aka Thermal Take Big Typhoon cooler.....max that would be 24X7 was 2.8GHz....not more than that.....plus TT-BT is a awesome cooler...
But I think with the stock cooler.a E6600 can go 3Gig ...for 24X7 use.,,
While overclocking you also have to take care of the temps......yeah E6300 can even do 3.7GHz...but not 24X7 use..
Sam :D Rulez :lol:
samrulez is offline
