Old 03-11-2006, 03:37 PM   #1 (permalink)
Default is my conifug right
hello friends ,
i recently buyed out a new config for me of the following specification....
pentium dual core 4 mb l2 cahe memory
intel d102gc2 motherboard
512 mb ddr2 ram * 2 @ 533 mhz of dyno
160 gb sagate sata hard drive
xfx nvidia pci xpress card of 256 mb ( i think of 6500 series)
17inch lcd samsung monitor of (sync master e700 )
logitech keyboard and mouse
sony dual layer dvd writer
a quantak cabinet with smps
a sony floppy drive
frand total of RS35000
the problem with the my configuration is that the onboard graphics with installing the driver provided with the board and without the installing the graphics driver is sluggish......is there any problem in this also the sound driver fails to be installl but with the service pack 2 its working properly
plz respond if u know something
thanks in advance
cool_anish is offline
Old 03-11-2006, 04:12 PM   #2 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Re: is my conifug right
Originally Posted by cool_anish
Pentium dual core 4 mb l2 cahe memory
Pentium Dual Core........I guess u mean Pentium D. What is it you would be using your system primarily for?
sam9s is offline
Old 03-11-2006, 06:03 PM   #3 (permalink)
assasin's Avatar
Get urself an update from the Microsoft site.It'll solve ur problem for the sound part i.e u'll be able to install the drivers without SP2.The display being sluggish isnot a prob.But dude 4 the price u paid u cud hav got urself a better config wit an AMD proccy.
assasin is offline
Old 05-11-2006, 09:23 PM   #4 (permalink)
Lightbulb Re: is my conifug right
thanks in advance
I think its with the new Intel motherboards. I do have Intel 915GLVG and faced the same problem. By golly, I tried Windows 2000 Professional, Windows XP home, Windows XP professional with SP1 but that darn Audio driver straight away refused to install (asking for higher service packs). Finally Windows XP SP2 solved the problem. I think it works with Windows 2000 Professional too but higher service packs are needed.
I dont see anything wrong with your config but I feel that you overpaid for the same.
Odoj is offline
Old 06-11-2006, 12:31 AM   #5 (permalink)
arun77574's Avatar
Bro let me tell you some thing. the motherboard you have bought has got an in built ATI graphics card which is a rival of the Nvidia Gfx cards. so i don't think you can install both of them in the same comp. any way there must be some option to disable the onboard graphics card so that the external card plays its role well. check the official site of your motherboard for details. And about disabling the onboard graphics card... i'll let you know later because even i'm not sure about that. anyway before that i'm sure someone else would be able to help you with this.
arun77574 is offline
Old 06-11-2006, 02:23 PM   #6 (permalink)
thanks guys ....
for the support....
is it not posssible to run both my onboard graphics card and xfx graphics card simentaneously...
i recently checked for the drivers in the intel site for my mobo ...
theres a update for solving the audio problem...
plus they have provided the ati radeon graphics driver...
am in a dilema whether to format and try to install the new drivers and the nes bios features....
and is the price of config high ....
if yes...
how much would be its actual worth...
thanks again
Old 06-11-2006, 02:43 PM   #7 (permalink)
bang bang!
Chirag's Avatar
No. You can't keep ur onboard and xfx gfx enabled at same time. You will have to disable one thing. Disable onboard to use ur gfx card.
Chirag is online now
Old 06-11-2006, 02:56 PM   #8 (permalink)
Smile Re: is my conifug right
thanks bro ...
but why so ....
would buying ati graphics card solve it
Old 07-11-2006, 01:18 PM   #9 (permalink)
arun77574's Avatar
its not like that. usually the external Gfx cards have more memory and better performance than the onboard stuffs. this is because the onboard gfx card has only the nessacary features and limited memory which is required for optimum performance. in case of a high quality graphics game or a high defined video, the external gfx card should perform better. so for those who have a tight pocket the onboard stuff is more than enough.
Remember: besides all these the compatability is more important.
And about disabling the onboard graphics-> get into BIOS-> goto integrated peripherals-> search for " onboard graphics " or something related to it.-> disable it.
Old 07-11-2006, 03:03 PM   #10 (permalink)
Cool Buddy's Avatar
You can use only one graphics driver at a time, either the onboard one or your graphics card, not both. The CPU while processing data, identifies the graphics part and sends it to the graphics card to be processed. you may thus guess it yourself that if there are 2 graphics drivers the CPU may not do its work properly. And anyways a dedicated graphics card will always be better than the onboard one. uninstall the drivers for the onboard graphics and your system will work fine
Cool Buddy is offline
Old 08-11-2006, 03:33 PM   #11 (permalink)
thanks a ton guys...
hat's off to u
remember your creator
Old 15-11-2006, 01:10 AM   #12 (permalink)
hello friends ,
a sony floppy drive
thanks in advance
hey guy, dont buy this floopy drv. floopies can be currepted ata any time.
but u can buy pendrive.
rgcrocks is offline
Old 15-11-2006, 11:09 AM   #13 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Man i have the same mobo......
u cant install ur sound card driver w/o sp2 of xp
rest abt the graphics driver n gpu...................
u cant use both of them simultaneously
if u got a dedicated gpu its hell better than an onboard gpu......
n joy
codename_romeo is offline
