Old 01-11-2006, 09:02 PM   #1 (permalink)
d
Default Which upgrade?
I've a rig running an Athlon64 socket 754, 1GB ram and a 6600GT. I'd like your opinion on which upgrade you think is better :
(a) the cheaper option being change my card to a 7800GS AGP
(b) switch to socket 939, get a new mobo, processor, and preferably two 6600GT's for SLi
I'm on a limited budget so .. do the math.
Thanks in Advance.
The torquemaster rules.
d is offline
Old 01-11-2006, 11:40 PM   #2 (permalink)
assasin's Avatar
Default Re: Which upgrade?
Why do u wanna buy a socket 939 when AM2 is available.It wud be better if u get urself a new mobo & processor.Dont upgrade ur GPU now.Wait 4 DX10 cards to be launched,see if any card fits ur budget and den get urself a card.
assasin is offline
