I am planning to Buy a DVD Writer by this Sunday 5th Nov. Please recommend me a good brand. In Digit reviews LiTeon always scores high. Where can i get Liteon DVD writer? Also plz give ur personal experiences in case u have used it. What is the price range and suggest model no if possible. Please reply guyz bcoz its urgent
Try and go to a computer shop you will find the dvd writers there.
better to avoid Samsung they are crap. you can easily buy a lg one, should not cost more than 1950 odd. you might get a liton as well - it would probably be cheaper than lg.
Change is Nature, the part that we can influence; and it starts when we decide.
Hi guys,
I am planning to buy an internal DVD writer positively in next 2-3 days.
I am currently planning to buy "LiteOn 165P6S".
Please tell me is it the right choice????? reply needed urgently...
