Old 31-10-2006, 05:51 PM   #1 (permalink)
Unhappy Hard Diask Not Detected!!!!! Help!!!!
Hi Everyone,
This is a long one so please read :
I have a Samsung 40 GB hard disk and a Seagate 120 GB Hard Disk. My 40GB hard disk is my primary master and the 120GB one the primary slave. Recently i took my 120GB hard disk to a friends house to get some songs and movies!! And the when i came back n plugged it in the 40GB (the primary master) did not get detected. I connected it to the same IDE cable!!! But when i connected the two hard disks on different cables. They both were working fine!!! Earlier there was no such problems as i connected them to the same IDE cable. Please help.... because if i dont get them to work on the same cable, i wont be able to connect my DVD-Writer and Combo drive as the IDE cbales are too short!!!! HELP!!!!!
hell_storm2004 is offline
Old 31-10-2006, 07:08 PM   #2 (permalink)
sknowonweb's Avatar
Default Re: Hard Diask Not Detected!!!!! Help!!!!
there are something called Jumper Pins in the back of the HD . The pins positions are labeled in the HD . Replace pins according to the labels suuch as slave or master and try again .
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
Old 01-11-2006, 04:53 PM   #3 (permalink)
I think they are ok... could there be nay other probelm??? Anyways, I'll check n confirm!!!!
Old 01-11-2006, 05:06 PM   #4 (permalink)
:-o
aakash_mishra's Avatar
Check your IDE cable on other computer I think problem lies there............
www.amiable.in
aakash_mishra is offline
Old 03-11-2006, 09:26 PM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
Problem solved or not?
y u people dont reply with the solution at the end when ur problem gets solved or may b give a second chance for the users who havnt seen ur thread?
Manshahia is offline
