Old 31-10-2006, 03:37 PM   #1 (permalink)
sweetricha07's Avatar
Default Cd doesnt get detected....
I recently bought a combo drive but right from day one it was giving me some troubles. Sometimes it simply refused to detect the cd/dvd inside or at other times it used to detect the presence of a disk inside but didn't used to read from it. After opening the drive and rotating the disk a little everything used to work fine. I thought there was a problem with my drive so I had it replaced but later on I discovered that any drive that I attach to my PC gives me the same problem. Any help ????
sweetricha07 is offline
Old 31-10-2006, 04:17 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Cd doesnt get detected....
This is a driver related issue. Is operating system detecting your CD Drive? Can you see CD/DVD icon im my computer? If yes..
Try these steps:
1. Perform a system restore to the best working time.
2. Make sure you are inserting a good disc
3. Update the drivers to the latest version.
Do revert back with feedback.
Kiran Kumar R
Kiran.dks is offline
Old 01-11-2006, 07:00 PM   #3 (permalink)
Hi. Yes, there is an icon in My Computer, I have tried System Restore, installing Windows, updating drivers. Nothing has worked uptil now.
Old 01-11-2006, 07:06 PM   #4 (permalink)
The Devil's Advocate
iMav's Avatar
chk the cables .... connect the cd drive to the same cable as that of ur hdd and then see
http://beingmanan.com
iMav is offline
Old 01-11-2006, 07:08 PM   #5 (permalink)
"A little learning is a dangerous thing; drink deep, or taste not the Pierian spring: there shallow draughts intoxicate the brain, and drinking largely sobers us again."
__________
Tried changing IDE as well. Didnt solve the problem.
Last edited by sweetricha07; 01-11-2006 at 07:08 PM. Reason: Automerged Doublepost
Old 01-11-2006, 11:52 PM   #6 (permalink)
assasin's Avatar
R d jumper settings correct for CD/DVD drive.Check the jumper setting.
assasin is offline
Old 04-11-2006, 10:56 AM   #7 (permalink)
yaar, the jumper settings are correct. the disk inside the drive doesnt get detected not the drive itself and that too sometimes.
Old 04-11-2006, 11:29 AM   #8 (permalink)
assasin's Avatar
What chipset-based mobo do u hav?
assasin is offline
Old 04-11-2006, 11:37 AM   #9 (permalink)
speedyguy's Avatar
did u try swapping ide cables for ur drives...put it in pri master slot n plug ur hdd to sec or slave...if still d same u got driver problems....wich os u using?
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 04-11-2006, 03:32 PM   #10 (permalink)
assasin's Avatar
Just try 1 thing.Update the firmware of ur combo drive.Chances r dat it'll solve ur prob.Had a similar prob wit my SONY DRU-720A.crossflashed it to a Liteon SOHW 1693S and had no probs after dat.It wud be better if u mention ur drives Make and model no here cuz if u flash the firmware in a wrong way ur combo will be dead...
assasin is offline
Old 04-11-2006, 05:13 PM   #11 (permalink)
I've tried all the IDE slots. And thanx abt the firmware choice. I'll try that one out.
