Old 31-10-2006, 03:08 PM   #1 (permalink)
Default Buying USB Flash Drive - Need advice
Guys, I want to buy a USB Flash pen/thumb driver. I've got about rs.5000 to spend, must have good capacity and trasnfer speed. Im gonna use it put photoshop portable n other software.
Please adive me the banrd, model n where to buy.
Thanksss
DON'T YOU DARE CLICK THIS : http://kevan.org/brain.cgi?the.unforgiven
Ultimate Z Fighter is offline
Old 28-02-2007, 12:31 PM   #2 (permalink)
Default Re: Buying USB Flash Drive - Need advice
The best I've found for your price range is Kingston Data Traveler (256 MB to 2 GB) at Shopping.com. PickyGuide also has some good advice.
lorrainejames is offline
Old 28-02-2007, 12:34 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^what r u saying man ???? he has 5000 rupees not 500
@ultimate , why r u speding so much for a usb flash drive ???? u can get kingston 4 GB for less than 2000 rupees. That shall be more than enough for ya.
n00b forever...
~Phenom~ is offline
Old 28-02-2007, 12:44 PM   #4 (permalink)
Shasanka_Gogoi's Avatar
5000 bucks!!!!!!!!!!!! Thats toooooooooooo much for a USB drive. U could easily get a 1GB for less than 800 and for around half of ur budget, I think u could easily get one with 4Gigs, If u are a Digit reader, go through this months issue, It will help.Thanks..............
A little advise- If u really have 5000 to spare, I suggest u go for a 250 GB internal SATA Hard Disk from Seagate and invest in an external casing, both would be within ur budget. And with that u could have 250 GB's of external HDD space, Thats way above any USB drive...(Ur 250 GB will also be connected through the USB). Only cons is that , it will be a tad bigger but than its 250 GB's........................
Shasanka_Gogoi is offline
Old 28-02-2007, 12:53 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
YaH that's the best option if size doesn't matter for you...
Else go for Transcend brand.
Nokia N86 8MP
Lucky_star is offline
Old 28-02-2007, 01:06 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
trancends(v30)...2 GB 700-800 bucks.but U have told that u need speed..than I will suggest trancend jetflsg160 and jet flsh168
ravi_9793 is offline
Old 28-02-2007, 01:16 PM   #7 (permalink)
Thanksss
Photoshop may work from a usb drive but it will be too slow since these usb drives are slow, better get a 80GB segate 2.5inch disk with a usb 2.0 casing &u will fly with photoshop, or if u can spare bit more than go usb/firewire combo, discussed here.
Is firewire faster than USB 2.0?
ranjan2001 is offline
Old 28-02-2007, 10:33 PM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
yeah u can get jetflash v30 4gb for ~1.6k. they shud be good enuf. but then loading photoshop from it mite take a hell lot of time. internal is internal! external usb cannot match that speed!
infra_red_dude is offline
Old 28-02-2007, 10:45 PM   #9 (permalink)
Quite true, but I use 7200 rpm portable disk with usb 2.0 & it works fine as normal disk.
Old 28-02-2007, 11:18 PM   #10 (permalink)
Learner
Kniwor's Avatar
An external USB flash drive will be quite slow, but If u are gonna compromise a bit on portability, just get a 40Gb laptop 2.5" HDD, and get a good plastic casing for 1-1.2k, this will cost around 3.8k but will be a fast/good solution to use portable Photoshop.The read write speeds will be about 20mbps, enough for what u need.
another way is suggested above, getting 250Gb sata and external casing, but it will be too bulky, and will need external power, quite irritating for an external drive.
Kniwor is offline
Old 01-03-2007, 12:02 AM   #11 (permalink)
Wire muncher!
actually finding a 7200rpm 40gb laptop hdd is a tuff job!!! casing is fine.. u can get a good one for 500bucks... but still running apps alike openoffice portable is fine.. but surely not photoshop! eager to see the results of the original poster!
Old 01-03-2007, 12:08 AM   #12 (permalink)
Not anymore.
Its easily available here in delhi nehru place, both western digital & seagate.
I bought the seagate 80gb for 6900/- plus extra casing.
If u cant find 7200 rpm then atleast have 5400 rpm one, not slower than that, earlier I used that one with usb1.1 on my old system.
Old 01-03-2007, 02:43 PM   #13 (permalink)
An internal 250GB SATA will be quite faster than any USB drives I suppose.
Old 02-03-2007, 01:20 AM   #14 (permalink)
royal's Avatar
Question Re: Buying USB Flash Drive - Need advice
Are you referring to cases with fans?If yes then are they too bulky to be carried in pockets ?
royal is offline
Old 02-03-2007, 03:49 AM   #15 (permalink)
man u can surely get external hard drive for that amount of money..but if u want usb drives...gigabyte is lightweight...small,handy,portability is more than kingston and transcend.....much more sleek than other brands.....id ont knwo abt speeds....but its costlier than the aboove two
Abhishek Bhattacharya
abhishek_del is offline
