Old 31-10-2006, 11:47 AM   #1 (permalink)
Default Intel Core 2 Duo Vs AMD AM2
Which is the best config according to you guys ??
Intel Core2 Duo Based
Intel E6300 Conroe - 1.86 GHz 1066MHz,2 MB,LGA
Rs.8900
ASUS P5LD2-VMSE 945G,S,L,16xPCX
Rs.4900
Transcend 1.0 GB-DDR2-533 533 MHZ - PC4000
Rs.5300
Seagate 250GB - SATA Baracuda / Puma 7200r
Rs.4050
Total:Rs.23150
AMD AM2 Based
DUAL Core AMD X2 - 3600 AM2
Rs.6650
ASUS M2NPV-MX nF6150,V,16x, 6Ch S
Rs.4750
Rs.5300
Rs.4050
Total:Rs.20750
Mobile Expert !
vk123 is offline
Old 31-10-2006, 10:59 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Intel Core 2 Duo Vs AMD AM2
with only this 2 in hand i would say AMD one is better because of the Motherboard...
as C2D is at its best with E6600+ with a 965G (x3000 GMA)+ based mobo.. 945 isnt up to the mark with C2D...
if compair with E6600 with D965G RY board then C2D rock over any AM2 config... and if u can go higher then well its even better...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-10-2006, 11:41 PM   #3 (permalink)
assasin's Avatar
If budget permits buy the AMD x2 3800+ instead of the 3600+.Also try to get urself a 1DDR2 667 MHz ram.
__________
assasin is offline
Old 01-11-2006, 12:01 AM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
Cool Cofiguration Man
Manshahia is offline
Old 15-11-2006, 05:47 PM   #5 (permalink)
Sauray:
1st of all the guy is comparing Price vs Performance its obvious.
In that case conroe e6300 is aproximatly 183.00 @ newegg.
Am2 4200 x2 is also 183.00 @ newegg.
In whtch the Am4200 x2 will Trounce The e6300 with any MOBO!
yur_maker is offline
Old 16-11-2006, 12:41 PM   #6 (permalink)
It's me.....
Matrix's Avatar
Smile Re: Intel Core 2 Duo Vs AMD AM2
Is this price of Asus Board and AMD 3600+ AM2 64bit is correct nd latest.
Please tell what is the price of AMD 3800+ AM2 64bit.
Is this AMD 3600+ 64bit AM2 is better than intel Core 2 duo .
Thanks
Matrix is offline
Old 20-11-2006, 08:52 PM   #7 (permalink)
3800 am2 is 159.00 retail at newegg.com, Asus M2N-MX is 75.99 @ newegg.com.
The Core2 e6300 Setup would be at least 75.00 More total With a Cheap MOBO and 150.00 more with a decent MOBO.
The only good core 2 chip is the conroe the rest are Junk so dont use the term Core 2, Say Conroe because AM2 will mop the floor with 90% of the core2 chips.
And Price vs Performance AM2 mops the floor with any intel chip.
Any one who says different is a "FANBOY" and is Talking out there azz.
Now the Conroe core2's Do clock very well if your an OC'r But for the Regular User I would Still Buy AMD Unless Money was no Object.
I would Also consider Conroe if you wanted to spend more than 300.00 on a cpu until AMD brings down the prices of there faster chips.
Old 21-11-2006, 08:26 PM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
@vk
Wud certainly recommend AMD over Intel in ur case.
U shud c d comparison which DIGIT carries dis month. Its a complete one..
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 21-11-2006, 09:07 PM   #9 (permalink)
bos
i am digital student( maya). can u select a machine.
thanking you
ani.taczila is offline
Old 21-11-2006, 09:34 PM   #10 (permalink)
vasulic's Avatar
I always prefer intel
vasulic is offline
Old 21-11-2006, 09:50 PM   #11 (permalink)
Aniruddh's Avatar
I M DREAMING OR WAT??ANY DAY E6300 IS BETTA THEN 3600.3800,4200 X2 AMD PROCCY...AM2 HAS NO FUTURE AS AMD'S NU SOCKET,PROCCY R GONNA B OUT SOON WID 65nm,I M REALLY SHOCKED TO C SO MANY PEOPLE SUGGESTING AM2 OVER CONROE...MAN JUZ GET URSELF A E6300 WID A DECENT MOBO IF U CAN THEN GET 965 ELSE 945.EVEN WID 945 CONROE IS GONNA BEAT AM2 BY A BIG MARGIN.
Aniruddh is offline
Old 28-11-2006, 07:39 AM   #12 (permalink)
Money is why...
For the money a low budget AM2 will mop the floor with a low budget conroe and the conroe will still cost more.
Not everyone has a million dollars to spend on an unlimited system.
I myself have a Dual Opie and the wife has a Conroe e6600 and My opie will trash it on anything.
Not to mention I have not had a crash on My Opie in a 2 yrs while the conroe bsods Regularly.
I like The Conroe for a single cpu It performs pretty well but by no Means is it King as All the serious Geeks have Opie's no Conroe's.
Opie's scale Better than anything out There.
You Fanboy Trolls Should stay in the closet.
When a Better Intel chip Is Invented I'll be The 1st to Buy it.
For Now it like this.
For low end dualcore get AM2.
Midrange Systems are a tossup.
For Highend get the Conroe.
For Geek Crazy Get Dual or Quad Opteron.
(Remember Only the conroe Intel Chip is any good, The rest are Basicly Junk)
So don't think You have a great chip just because its an Intel Duo core because Most of them are sub standard.
Old 28-11-2006, 08:09 AM   #13 (permalink)
^^What bull$hit... the slowest core 2 duo E6300 is faster than the top end athlon 64 at stock speeds(other than the fx). Not to mention it clocks insanely well with a bit more juice. Everyone who cares about performance has a conroe now... i dumped an amd64 setup for a c2d and couldn't be happier. If your wife's conroe bsods, its probably cos of some board issue or bad ram or insufficient power or simply spyware/malware/viruses. Lame posts like these lead to only confusion and nothing more. Now go jump in a well before making such retarded posts again.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 28-11-2006, 08:19 AM   #14 (permalink)
caleb's Avatar
Peace Brother
caleb is offline
Old 28-11-2006, 08:24 AM   #15 (permalink)
^^Yeah I guess i went overboard... apologies. But nothing pisses me off more than when folks with half knowledge try to push home their opinions like what the poster above me did.
Ch@0s is offline
Old 28-11-2006, 11:50 AM   #16 (permalink)
The High 5 Flyer
sam9s's Avatar
I absolutely agree with you, they dont know what they r suggesting. Jugnu go for C2D strightaway. Do a simple review research on google for both and you will know what I mean.
__________
And I fully agree with you too. Why dont you guys do a simple online research before making an openion. Its a clear clear fact that C2D is far better chip than any other, even at stock speed. And as chaos said it overclocks like a charm, hell even if you are not OC its a damm sexy chip.
sam9s is offline
Old 05-12-2006, 10:57 AM   #17 (permalink)
These Turds are kids who Probably do not own either and have celerons that there Gramma gave them.
Research and You will see.
As I stated Conroe clocks well if your an overclocker but remember the chip speed is set by intel for a reason and many have stability issues with over clocking.
Not to mention shortening the life or destroying Your setup.
AM2 4200 2x is Faster than Conroe e6300 @ just About anything, Just research it.
Both chips cost the same, except You will pay More for an Intel MOBO.
Stock AM2 2x is hands down the victor.
If You Have OC'ing in mind then I would get the e6300.
Only a schoolboy / Fanboy Retard would say different.
My Dual Opie Can Defrag, Virus Scan, encode a Movie ,Listen to an mp3 and Play FEAR Full out All Simultaniously With out a hickup.
This would Make the Wife's e6600 Puke !
