Old 29-10-2006, 08:28 PM   #1 (permalink)
godsownman's Avatar
Red face Processor fan not working
Hello,
Since this morning, Ive noticed that my processor fan isnt working.
Can somebody please giude me with what is to be done.
I know that I without the fan the processor can get ruined but right now, I am externally cooling it (processor) with a table fan and it seems to be working. I am keeping the durations also short.Is it possible to keep the fan n heatsink out and then run the computer? So that it cools better?
My Config is : Intel Pentium III Processor with a Intel 810 motherboard.
I need your help ,
Tomorrow Morning Im going to go to the market to look out for a new fan.
What all do I need to do there in order to identify the correct one that will exactly match my Piii , motheboard and heatsink.
Please giude me exactly with whatever advice you all may be having. I dont even know what questions I should ask.
Thanks a lot.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 29-10-2006, 08:35 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Processor fan not working
U need a 230 watt power supply
__________
u can even buy an 300 watt power supply
Tech Geek is offline
Old 29-10-2006, 08:56 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
just take ur old fan to market show them & get a same new one
also take ur headsink & verify that it suits ur New Fan
satyamy is offline
Old 30-10-2006, 10:31 AM   #4 (permalink)
godsownman's Avatar
__________
Hey,
Im talking about a processor fan!, where do I need a 230 watt power supply
Looks like someone was day dreaming
SOME MORE QUESTIONS
Anyidea what would be the price of the fan approximately.
Also Do I have to apply the thermal paste again?
Old 30-10-2006, 10:47 AM   #5 (permalink)
Come get Some
DukeNukem's Avatar
Is it a cased CPU????? (one which is slotted in like ram)
Though Processor Fans dont come alone (They will tell you this)
you'll get it for about 150 (both fan and heat sink (local made))
else
buy the fan alone by taking your fan to them it will cost about Rs.40-70
If it require removing the heat sink THEN YES
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 30-10-2006, 11:25 AM   #6 (permalink)
Welcome To The Jungle
sysfilez's Avatar
hey friend its recommended that when u remove the heat sink then apply fresh thermal paste after cleaning the surface. i think u sud do that if u r ocing or something. as per cpu fan it will cost somewat 50/-. it will be better if u carry the heatsink and fan along with u when u go to the market.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 30-10-2006, 01:03 PM   #7 (permalink)
samrulez's Avatar
Try cleaning the fan with a brush...and if it still dosen't work.....try the terminals....and if all this is in vain...then get a new fan from Lamington Rd..........it should cost you about ~500 bucks
Sam Rulez
samrulez is offline
Old 30-10-2006, 01:30 PM   #8 (permalink)
godsownman's Avatar
No its a normal chip based processor.
The basic thing I've got to remember while purchasing this is that it clips on to the clips provided on the processor foundation, right?
About the Thermal paste, how is this thing sold, coz I only need a small blob! n its never going to be used again after that.Touchwood
Anyway thanks guys for all the help.I'll make my trip this evening .
Adios.
Old 30-10-2006, 04:33 PM   #9 (permalink)
Eazy's Avatar
Check this page for fan maintenance .... oiling of the fan....
http://www.dansdata.com/fanmaint.htm
Eazy is offline
Old 30-10-2006, 04:53 PM   #10 (permalink)
Redshary's Avatar
Just a thought...it may not be applicable. The fan on the processor does not normally come on until it reaches a critical temperature. load your system and see if it runs, if not go ahead and buy a fan. cheers.
Strengh & Honour[Gladiator]
Redshary is offline
Old 30-10-2006, 04:59 PM   #11 (permalink)
samrulez's Avatar
Well thermal paste will be available at most of the shops at Lamington Road.........branded tubes cost 350+.....or even 450-500 buck ......
Local paste are also available they cost about 50-100 bucks..
Sam Rulez
samrulez is offline
Old 31-10-2006, 12:14 AM   #12 (permalink)
godsownman's Avatar
No ur mistaken, the fan starts the minute you power on the computer until you power it down.
Anyway, Guys thanks a lot. I got a new fan from Lamington Road today, fitted it too n everythings fine,touchwood.
I got a small sachet (enough to last a single use) of thermal paste with the fan in the box.
Thanks once again.
Old 31-10-2006, 10:18 AM   #13 (permalink)
samrulez's Avatar
Hey.....which fan did you buy then even has thermal paste ? How much did it cost you?
Sam Rulez
samrulez is offline
