Old 29-10-2006, 06:54 PM   #1 (permalink)
kkg_mjh's Avatar
Unhappy Help somting happen to my cpu
My system is not operating from last force shutdown by power off button.
When i turn on my system the front led of power and hdd are on but no processing is happening like bios loading etc ,
help me as soon as possible
** If u want to learn how to crash learn from MICROSOFT )
kkg_mjh is offline
Old 29-10-2006, 06:56 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Help somting happen to my cpu
why did u shut down like that
Tech Geek is offline
Old 29-10-2006, 07:01 PM   #3 (permalink)
kkg_mjh's Avatar
Hey that is because of ****ing microsoft
kkg_mjh is offline
Old 29-10-2006, 07:03 PM   #4 (permalink)
Tech Geek's Avatar
I think u have to Format the PC
Old 29-10-2006, 07:07 PM   #5 (permalink)
kkg_mjh's Avatar
The error is from hardware side not from operating system
kkg_mjh is offline
Old 29-10-2006, 07:35 PM   #6 (permalink)
Tech Geek's Avatar
Is ur PC starting til the welcome screen?
Old 29-10-2006, 07:46 PM   #7 (permalink)
kkg_mjh's Avatar
No welcome . screen and for your info my monitor is fine
kkg_mjh is offline
Old 29-10-2006, 07:49 PM   #8 (permalink)
Tech Geek's Avatar
May the power is not reaching the parts or somthig has spoilt
Old 29-10-2006, 08:10 PM   #9 (permalink)
kkg_mjh's Avatar
Yes i am also thinking so
kkg_mjh is offline
Old 29-10-2006, 08:11 PM   #10 (permalink)
Tech Geek's Avatar
Open the cabinet and see.
Call the persons from whom u bought.
Where do u live?
Old 29-10-2006, 09:17 PM   #11 (permalink)
Alive Again...
satyamy's Avatar
first of all
open ur PC cab
n than start ur PC, see that ur processors fan is running or not if yes than check that may be their is some loose connection
n pls write in detail that wht do u have in ur PC
may be ur lan card is been shorted (try removing that), or may be one of ur ram
if Power led & HDD led is on that means no prob with soft & ur mobo & harddisk is also fine
satyamy is offline
Old 29-10-2006, 10:38 PM   #12 (permalink)
Phenom II X4 920 Owner
prateek_san's Avatar
please give more details....we can't see ur pc and say sol..
"A strong positive mental attitude will create more miracles than any wonder drug." - Patricia Neal
prateek_san is offline
Old 30-10-2006, 11:51 AM   #13 (permalink)
kkg_mjh's Avatar
What kind of detail i have to give . Please specify
kkg_mjh is offline
Old 06-11-2006, 11:20 PM   #14 (permalink)
Alive Again...
satyamy's Avatar
did u solved ur prob or not........?
satyamy is offline
Old 07-11-2006, 06:28 AM   #15 (permalink)
kkg_mjh's Avatar
Problem is solved
kkg_mjh is offline
Old 07-11-2006, 11:20 AM   #16 (permalink)
Alive Again...
satyamy's Avatar
can u tell us how ur prob is solved so that it'll help newbies...
satyamy is offline
Old 07-11-2006, 07:33 PM   #17 (permalink)
kkg_mjh's Avatar
my hardware vendor solve it he says there was some prob in IC of the MotherBoard
kkg_mjh is offline
Old 07-11-2006, 07:46 PM   #18 (permalink)
Tech Geek's Avatar
Why do u hate microsoft so much?
