Old 29-10-2006, 06:22 PM   #1 (permalink)
Question Seagate SATA HDD woes on 965RY
Hi Friends,
[Posting a new thread with clear sub, I request the MOD to close the thread with sub "Intel DG965WH Vs DG965RY ?"]
Was not in town for last few day. Atlast y'day I brought my PC with following Configuration:
Intel 965RY
C2D 1.86GHz E6300
Transcend 1G 533 MHz (Planning to xchange it with 667)
Seagate 200 GB SATA 7200
Initially had problems with RAM Compatibility, but then Transcend worked.
Now the problem am facing is, my BIOS shown all the configurations properly but when i boot my PC with bootable winxp sp2, after loading the setup file the setup says "There are no fixed disks available to the system". I tried booting with a floppy and FDISK also says "No Fixed disks available" ( Not sure if we can use FDISK to partition SATA hdds) . I tested connecting the SATA cable to all the SATA ports and with different SATA cables but everying in vain.
But when I connected my old Samsung IDE HDD 80 GB to the IDE connector (thank god I have an option of 1 IDE connector in 965RY) i was able to smoothly run the setup.
Friends, please tell me what could be the problem??? I dont want to continue with my IDE but want to use SATA technology and get maximum performance out of my above configuration.
Thanks & Regards
Dev
Innovator is offline
Old 29-10-2006, 06:47 PM   #2 (permalink)
jz2linkinpark's Avatar
Default Re: Seagate SATA HDD woes on 965RY
it could be because you didn't attach the cables properly, especially the sata cable....cuz i had a similar problem when i inserted the cable into the wrong slot(i put it into the hole on the other end of the cable side)...lol
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 29-10-2006, 08:06 PM   #3 (permalink)
Unhappy Re: Seagate SATA HDD woes on 965RY
Thanks for the prompt reply. I tried with all the SATA ports which as following on the board and on the SATA HDD:
____
____
____|
____|
But still the same problem....
Old 29-10-2006, 08:16 PM   #4 (permalink)
varkey's Avatar
maybe ur copy of winxp doesnt have sata drivers. i had this prob before and was solved whn i used a diffcd with drivers integrated.
anyway whts ur opnion abt the boad dg965ry im planning to buy that.
please post the price of the various componenets u purchased and from which city u are from.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 30-10-2006, 05:34 PM   #5 (permalink)
Hi mr.Innovator.. I am too from hyderabad.. I want too purchase cpu on C2D in next week.. can u post the prices at which you bought parts.. and did u purchase from CTC in secunderabad.. plz post in which shop you bought the cpu.. thanks in advance..
robogeek is offline
Old 30-10-2006, 05:47 PM   #6 (permalink)
See in the bios and set your hard disk controller is set to IDE emulation mode. I think its in raid mode which will require the SATA controller drivers to be provided on a floppy. (You need to press F8 once the blue loading screen prompts you).
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 30-10-2006, 11:02 PM   #7 (permalink)
Hurray Freinds !!!
I was able to resolve the HDD problem, I just Xchanged my Seagate 200 GB 7200.9 SATA I HDD with 7200.10 SATA II HDD and guess what, the XP setup boosted and detected my HDD.
Friends, Thanks for lot for your kind responses and suggestions which made my life easier. Kudoos to all of you
Old 31-10-2006, 06:42 AM   #8 (permalink)
varkey's Avatar
good to know that the prob was solved.
it would be nice if you could post the prices at which u bought the items
varkey is offline
Old 31-10-2006, 12:41 PM   #9 (permalink)
gxsaurav
Posts: n/a
u will simply need to make a slipstreamed XP SP2 CD, I had similar problems, so i simply made myself a XP SP2 + 865GBF motherboard SATA drivers slipstreamed CD with nlite, try it, it's quite good
Old 31-10-2006, 01:54 PM   #10 (permalink)
Here is the price list of my configuration:
Intel 965RY - 6400/-
Core 2 Duo 1.86 GHz E6300 - 8850/-
DDR2 Transcend 1 GB 533 (Single) - 6300/-
Seagate 200GB SATA II 7200.10 - 4000/-
Intel Core 2 Duo E6300, Intel DG965RY, Transcend 1 GB 533, Seagate 200 GB 7200.10 SATA II
