| Forum |
#1 (permalink) |
WOW... are you?
I suspect my network card, bcoz everytime my PC boots... it takes ages for network connection menu to load. By the way, i took my sound card out... my AGP card... and everything!!! I check my RAM... and HD and all!!! Is there any way, i can check my PC ? any diagnostic tool ? like a suite or something, that will check my IRQ conflict and all ? HELP Gsoul... |
#2 (permalink) |
Ur operating System ?? Ram ?? Background Softwares...
When was the last time you made a scan for viruses, threats, spyware.. is here any specific aplication on which the PC freezes...
!!!From DusT it StartS...... to DusT will EnD!!!! DusT = ME Rate me if was clear to you |
#4 (permalink) |
WOW... are you?
i have like... changed OS, 3 times... and each time same PROB !!!
anyways im sure it's Network card thing... cause, i removed it... and not a single freeze !!! Then i pop it in... and it's like "welcome back" anyways, i need the network card, cause i connect to the NET, with it... so any thing i can do ? HELP !!! |
#5 (permalink) |
check for the latest drivers for that network card.....
anyways which card is that..".name."
#7 (permalink) |
Distinguished Member
c this too Pc Freezes All The Time
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
