| Forum |
#1 (permalink) |
According to the probe, 1. MY CPU FAN Speed is 1600+ and its stating it as ABNORMAL and showing it as RED ZONE alert. 2. POWER 2 Fan (Dont know what exactly this is) is running at 3k+ rpm and stating it as ABNORMAL too with RED ZONE alert. 3. MB temp is around 55+ and even that is shown as red zone alert. What may be the reasons ? There one more problem. When i start software PCTVi, a msg comes which says NO TV devices available. What could wrong here ? __________ Also pls tell me what should be the ideal values for the above problems. Thank you __________ Are there any chances of compatibility issues with Monitor, TV tuner card and graphics card ? If yes, are Samsung 940BW, Pinnacle PCTV 110i, XFX 7600GT compatible with each other ? I m still not unable to fix this TV tuner T_T I get "No TV capture devices available for playback" msg on starting PCTV software. __________ Someone PLS help me out with this T_T Last edited by suhas_sm; 29-10-2006 at 08:24 PM. Reason: Automerged Doublepost |
#2 (permalink) | |
Alive Again...
did u tried to reinstall ur drivers n u did'nt specified which OS ur using |
#3 (permalink) |
For the 1st problem,
Check the values at Setup to verify that the values reported by PC Probe is correct. To enter setup refer to your motherboard manual. I guess it must be "pressing F2 during booting". I hv seen on some MBs the Software report incorrect values. I use MSI K8-NGM-V MB. The average values in my system r: CPU Fan Speed: 5200 MB Temp: 45C CPU Temp: 50C I hv also installed an xtra Fan. But its speed is not shown since it is not connected with the MB. I dont hv a TV tuner card. Wait for other members to help u out. I hv not heard of any compatibility issues with Monitor, TV tuner card and graphics card.
Driving on the highway is not a competition. It is a co-operation, the sharing of a limited resource. |
#4 (permalink) |
Thank you for teh replies. Well the TV tuner problem has been solved. But the Picture qaulity is very bad
@Subhajitmaji I think u are correct. I have seen ppl cussing PC probe software for showing wrong values at some places on net. May be i should check it out with my System setup itself |
#5 (permalink) |
Welcome To The Jungle
@suhas sm
i have a asus mobo but then i have never used asus probe coz it gives wrong values. just chek out other s/ws for measuring temp n speed. ur picture quality is bad may be due to poor cable signal, i had de same probs but after reporting to cable wala and changing the wires, its ok now.
Me n My Canon EOS 350D with EF 50mm f1.8 |
#6 (permalink) |
@suhas_sm
Most Welcome Download Speed Fan from here. It usually works successfully on Asus Motherboardshttp://www.almico.com/sfdownload.php
| Bookmarks |
| Thread Tools | |
| Display Modes | |
