Old 28-10-2006, 06:26 PM   #1 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Default strange problem.......
recently when i try to switch on my pc, it doesnt start.....the pros. Led remains on continously and the monitor remains on the standby mode.....the pc sometimes starts perfectly and then i face no problem whatsoever.......hence i m convinced that it is not a heating prob.....plz help.........
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 28-10-2006, 06:28 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: strange problem.......
some losse connection in the plugpoints i think so
Tech Geek is offline
Old 28-10-2006, 09:23 PM   #3 (permalink)
coolsunny's Avatar
check for loose connections. if it does not works remove ur r cmos battery & RAM.& reinstall them.tell me if it works or not.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is online now
Old 28-10-2006, 09:57 PM   #4 (permalink)
vandit's Avatar
done but no use......
vandit is offline
Old 28-10-2006, 10:33 PM   #5 (permalink)
gaurav21r's Avatar
Disconnect and re-connect all cables including power cables.
Do you hear the RAM test beep during Boot?
do i have to write something here?????
gaurav21r is offline
Old 29-10-2006, 12:03 AM   #6 (permalink)
vandit's Avatar
no i cannot hear the beep....
vandit is offline
Old 29-10-2006, 12:08 AM   #7 (permalink)
gaurav21r's Avatar
Your RAM is faulty or loosely connected to the Motherboard...Since you say that it starts normally sometimes, it might be a loose connection.
If you are very very sure that RAM is not the problem, it must be power.
Old 29-10-2006, 09:36 AM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
Zsame Problem discussion here-- monitor led blinks,bt not working.pls help
__
s18000rpm is offline
Old 29-10-2006, 11:53 PM   #9 (permalink)
vandit's Avatar
some1 plz help........i cleared the cmos by the jumpers.....cleaned,inserted the ram in other slot....checked my monitor....working fine....checked all cables 4 loose connection.....inserted a new cmos cell....still not working....
vandit is offline
Old 30-10-2006, 12:01 AM   #10 (permalink)
:-o
aakash_mishra's Avatar
Try changing your data cable of HDD........
I too was having some prob like that I first reinstalled Win XP but then too my prob not solved then I replaced its data cable and my computer is fine now. I think it might work.
www.amiable.in
aakash_mishra is offline
Old 30-10-2006, 11:57 AM   #11 (permalink)
Welcome To The Jungle
sysfilez's Avatar
i think its a faulty ram.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 30-10-2006, 12:26 PM   #12 (permalink)
Come get Some
DukeNukem's Avatar
When RAM is Faulty. We hear a deep Long BEEEEEEEEp.
Well this case happens with my friend a year back
what i did for him is replaced every thing again (LAN/SOUND/AGP/RAM/HDD/FLP/CD/DVD/PROC) after tryin lot of other options
and don know how but "it comes alive."
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
