| Forum |
#1 (permalink) |
I lost my copy of digit which carried the speaker system review, and digit really is my bible, so can u guys pls help me out here..?? I need to purchase a 2.1 speaker system (2.1 because it is to be used primarily for music) and my budget is around 3-4k, else i would've definitely gone for the Altec Lansing MX-5021. But since I cant, Any suggestions..?? You might say that i'm an audiophile, with a budget |
#3 (permalink) |
Get Altec Lansing ATP3...way better than Creative Inspire 2.1.
Should be around 2.6k
AMD Athlon 64-2800@ 2.4 Ghz,Asus K8N,2X1GB DDR400 Transcend Memory @2.5-3-3-5,Segate 160GB PATA,LG GSA-H10N,BBA X800 XT PE,Windows XP+SP2,Vista Ultimate,Ubuntu 6.10,Altec Lansing ATP3,Philips SHP805 |
#5 (permalink) |
Sup' dude, Sup'
Altec Lansing ATP3 is far far far better than creative inspire 2.1
ATP3 has 4 drivers, 2 mid range drivers, and a powerful subwoofer. It's price is 2.8k and is the best in that range.
Introducing Windows Vista 2.0. Check it out at http://www.apple.com/macosx/leopard/index.html |
#6 (permalink) |
ok..
thanx a lot for the info.. i'll check out the reviews on the net as well.. secondly.. i have an old sony system, with two speakers (big ones), and two surround sound thingies.. and it gives reasonable sound with my worldspace.. now, should i stick with that, or should i get new ones..??? Edit: I also found these ones...what do u say to them?? Altec Lansing FX 6021 Logitech Z-2300 Last edited by prajneet; 27-10-2006 at 08:01 PM. |
#8 (permalink) |
try out F&D.relatively a new brand.has been around for a while.u might haven't heard this name.but believe me the speakers absolutely rock.
Water can flow or it can crash.Be Water my friend. |
#10 (permalink) |
FX-6021 is good. Very good bass. Though, sound crackles at high volumes. Why dont you look for Philips 2.1 PC-400 range?? I have them as one of my Front range speakers. And believe me, they are good. Specially, the tweeters sound too good!! Bass output is tight and doesn't faint at all. Moreover, there pricing is very attractive.
#11 (permalink) |
Altec Lansing should be your first choice. ATP3 is fine.
else go for Creative Inspire 2.1
You are a living magnet. What you attract into your life is in harmony with your dominant thoughts. |
#13 (permalink) |
i got a budget of upto 2k. Can anybody suggest a decent 2.1 set of speakers witihn this range. I was thinking of the Creative speakers (SBS 370) and the logitech one reviewed in IC CHIP this month (slightly above but will do). Please guide me.
#14 (permalink) |
The following is my opinion based on what I have experienced so far... And it is very generic and some specific models may have different features
In general, Creative speakers are well-balanced for good performance in gaming, music and movies.... Altec Lansing performs great in music and movies but only ok in gaming... Havent tried Logitech systems... Arun |
#15 (permalink) |
Macboy
Logitech Z2300 is a 200 watt RMS speaker system, compared to the ATP3's 40 watt? It is also THX certified and has got an 8 inch 120 watt RMS subwoofer. There's also the cost which is about 9.5k against the ATP3's 2.8k....
For budget, go for the Altec's ATP3....they're good.
I'm like a bird... |
#16 (permalink) | |
TheSaint
http://www.neville.in http://www.linuxrocks.in "The Future Is Open" |
#17 (permalink) |
No pain....No gain
One more vote for Altec Lansing ATP3, have been using for around 1 year. I would suggest that you listen to the demo of different systems then decide for yourself.
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#20 (permalink) |
I have decided to buy the Creative SBS 2.1 370 speaker set. The dealer has offered to sell it me for 1250. Plz tell me if the price is OK, or if it is possible to get a lower price for the same. If so, then please give me the address and contact no (Pref in Mumbai, Delhi or Pune).
#22 (permalink) |
Logitech x230 is gr8 for music nd gaming. Its neodimium drivers does a decent job nd souds are crystalline nd sharp nd bass too id gr8.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#23 (permalink) |
For a little over 3k, you can get the Altec Lansing VS4121 thats better than the ATP3. While you can't expect wonders in this price range, thats the most tonally accurate speaker I've heard around the price. Cheap and nice.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
