Old 26-10-2006, 01:30 PM   #1 (permalink)
ASH_DSG
Posts: n/a
Default Connecting Tv Through Motherboard
Hi Friends,
I have a motherboard Asus P5RD1- VM and Intel Cel. 2.8 ghz. CPU. My mobo has a tv_out pin on it just like as front usb connector. I want to know how can I connect my tv through this tv out pin? I have bought a tv out pin connector and conncet it with my mobo and then I insert my tv(vdo/o) pin to it and start the computer but nothing is shown on the Tv. Please help me how can I connect my TV to it or if I have conncet a wrong tv pin conncetor to my mobo. If yes then where can I find it. please help me. I'll be waitng for ur reply.
Old 26-10-2006, 03:22 PM   #2 (permalink)
Default Re: Connecting Tv Through Motherboard
where did u get connector i am searching it from long time.
Ravirdv is offline
Old 26-10-2006, 03:43 PM   #3 (permalink)
Look for an S-Video to Composite converter and use normal composite cable to connect your TV. If you have a better TV that supports S-Video or Component connections, use those connectors instead of composite.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 26-10-2006, 06:39 PM   #4 (permalink)
varkey's Avatar
are u sure this board has a tv-out connector cause the motherboard spec doesnt seem to mention that.
http://www.asus.com/products4.aspx?m...3&l2=11&l3=179
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
