Old 25-10-2006, 03:31 PM   #1 (permalink)
Default speaker problem
lately my pc speakers have started giving a strange shrill sound(like the one that comes when u adjust a mic). this sound comes when i increase the volume above a certain level using the volume knob on the speaker.also it comes irrespective of wether i'm playing an audio file,video or nothing at all. what's the reason and what can i do?
thnx
callmeastha is offline
Old 25-10-2006, 03:39 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: speaker problem
The speakers hav spoilt may be
Tech Geek is offline
Old 25-10-2006, 03:41 PM   #3 (permalink)
spyingshadow's Avatar
Wink Re: speaker problem
how old r ur speakers? This sproblem usually occurs when the speakers get old or a little damaged. u sure might be getting it when u would adjust the volume knob.
OR
It might be that you have enabled the 20-db boost in the mic settings n also kept the mic volume on. Just go to control panel-sounds and audio devices-advanced(volume tab)-now u will see a slider with mic written over it. Just lower the volume or select the mute option. U should get rid of it. Otherwise, u can go to the advanced options below it n disable the 20-db boost. If there is no button like advanced, just enable it from options.
IMPORTANT: if the mic volume slider is not present, go to options-properties-playback and enable the mic slider.
for any queries, just post again.
Cant catch vot ya cant see 8-)
spyingshadow is offline
Old 25-10-2006, 03:50 PM   #4 (permalink)
OR
speaker are some 4 yers old. dunno what 20-db boost is and cant find it's option.mic slider not present and cant find the optin to activate it.i have something called c-media 3d installed (display name Xear 3d).is that the cause?but it han't caused any problems till now
Old 28-10-2006, 03:13 PM   #5 (permalink)
Come get Some
DukeNukem's Avatar
VOLUME Knob of your Spk is the one responsible for that Sound.
replace it with a new one or Try Thinner or Kerosene oil on that knob to remove the carbon from it due to which you are facing the Problem but better is to replace it with new one as thinner or kerosene oil trick is only temp. sol.
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 28-10-2006, 04:09 PM   #6 (permalink)
tried oiling the knob.doesn't seem to work.i've observed that everytime i blow into or tap a small opening on top of my monitor(dunno what it does) sound comes like when we tap a mic. haven't noted it before. is this abnormal?
Old 28-10-2006, 04:16 PM   #7 (permalink)
Come get Some
DukeNukem's Avatar
turn off your MIC then (By Muting it)
and Change Your Mic if it Way too old
