Old 25-10-2006, 12:21 PM   #1 (permalink)
CT Squad's Avatar
Question CD data recovery pls help
i hav a samsung combodrive with Nero 7 premium. recently i burned a cd Sony CD-RW at 4x some wallpapers at multisession. and took it to computer that has Sony Combodrive with Nero 6. as multisession was turned on i burned some more data into that disc from that pc and when i came back i can only see the wallpapers which i burned not the data.
after several attempts of ejecting and loading i could only see the wallpapers. On the recordable side of the CD it is clearly visible some gap of about 0.75 cm b/w the 2 set of Data. pls anyone help me to recover all the files. I used CD check once delivered by DIGIT but it didn't work. Even ISObuster shows only the wallpapers. PLS HEEEEELP!!!!
I use windows XP sp2
256MB RAM
combo drive (samsung)
Nero 7 Premium
Success always occurs in private, and failure in full view.
CT Squad is offline
Old 26-10-2006, 01:15 PM   #2 (permalink)
Eazy's Avatar
Default Re: CD data recovery pls help
Download this freeware - BAD CD REPAIR v 1.0 - and check if it helps you ...
http://www.freether.com/takenow.php?...000a39e02fa632
Eazy is offline
