View Poll Results: What are the best mobos for Intel C2d
ASUS 3 27.27%
Gigabyte 3 27.27%
Intel 5 45.45%
MSI 0 0%
Other 0 0%
Voters: 11. You may not vote on this poll
Old 25-10-2006, 06:27 PM   #1 (permalink)
spyingshadow's Avatar
Default Chipping the Chipsets
Hey! I hv done a lot of scouting myself but thought taking a little bit more help would do no harm. I plan to upgrade after the nov issue of digit n I already hv decided upon e6300 n say i hv bought it. But, the only hckle i face is MOBO. Just getting confused every time. Tell me which is the best chipset, P965, G965, nforce 590, Sis 661fx/964 or any other?(except 975X as i think it will overshoot my budget) I hv a budget of about 7-10.5k. Plz Tell me 1 mobo each from gigabyte, ASUS, Intel n MSI. I like the gigabyte ga 965p dq6. I hv read reviews from reputed test centres n they say it is an overclocker's delight with a built in heat sink n no stability issues. I hv seen u all like ASUS. after all, both r taiwanese companies so duno which is better. i hv cheked their websites. (U might know coz i hv posted a lot of replies). I need support at least for overclocking, 2 front panel firewire, four front panel usb2.0 et al.
thnx in advance
__________
well, is asus p5b-e plus available in india? Love that one, all the power at hand and still at rupees. 7500 with just about enough oc
every1 around the world seems to like ASUS so I tohught i'll take the p5b if its available or else its gigabyte ga dq6
Cant catch vot ya cant see 8-)
Last edited by spyingshadow; 25-10-2006 at 06:27 PM. Reason: Automerged Doublepost
spyingshadow is offline
Old 25-10-2006, 08:08 PM   #2 (permalink)
Default Re: Chipping the Chipsets
Best chipset for C2D (not counting 975) is 965.
If you want to use SLI your only choice is a nForce chipset otherwise a 965 is the best.
drvarunmehta is offline
Old 26-10-2006, 09:34 PM   #3 (permalink)
Red face Re: Chipping the Chipsets
Thanks dharma, now tell me is there any p965 mobo from ASUS available back here? if not, Ga dq6 is.
