24-10-2006, 07:00 PM
monitor led blinks,bt not working.pls help
hi,
i m using p4, sound,vga onboard.
now wht i m facing s, whn i m switching the pc,cpu gets on.bt the monitor not getting switch on.its led gets flashed.whn trying to open the cd tray,no problm,its working,
can any one,guide me to trouble shoot?
waiting
thanks in advance
24-10-2006, 07:44 PM
Re: monitor led blinks,bt not working.pls help
Happened to me once.Check all the cables connection properly.
24-10-2006, 08:50 PM
gooby pls
check your ram and cables.
24-10-2006, 09:00 PM
Check all cables.
Maybe the refresh rate freq is set to some value not supported by your monitor???
24-10-2006, 09:03 PM
Alive Again...
ya right
First check all ur cables than check ur RAM
if wont work try to on u PC by removing some devices like LAN Card
25-10-2006, 03:19 PM
Come get Some
have you done any changes in BIOS recently ????
if Yes
Then Reset The BIOS for Relief from your Current Misery.
(To reset Bios Remove the Cell for About 5 minutes or if you Board has BIOS resetter Jumper DO IT)
28-10-2006, 05:45 PM
Are u using d845 gvsr mobo ? i had the same problem , cd rom ejects and mobo lits up inside the cabinet , every thing appears working , except for blank monitor ...i got my mob repaired 5 times from diffrent places, at intel they said it had no problem , but never worked more than an hour each time .... hope this didnt happen to ur mobo too
i was on the 3 rd year under warranty , i was not eevn given a new mobo
29-10-2006, 01:26 AM
Faced this problem few years before.
But the problem was with CMOS chip/battery. (cant recall exactly)
CPU was unable to send the sync pulse to monitor.
Do post, if you happen to solve the problem.
29-10-2006, 09:33 AM
a_g = JPKN
open your PC Cabinet & see if the Transistors (cylindrical things) around the Prcessor have SWOLLEN or have a Rusty LEAK overhead.
if you see it, then get your mobo repaired.
My friend suffered same problems.(his pc was 5-6 years old)
ASUS K53SV SX520D + BF3
29-10-2006, 09:42 AM
Manchester United
Faced this problem 2-3 months back. Seems like the resistors/transistors/capacitors in the monitor PCB have gone put. Do not open the monitor yourself, get it repaired by a service technician. Maybe he will take Rs.100-Rs.200 as service charge.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
29-10-2006, 02:00 PM
i removed all extra cards frm slots. still,same problm, tht,processr fan,smps every thing working,bt i cant get the normal buzzer whn booting. no output to monitor too.i ckcked with two monitors.bt same result.
i m using Ashrok mother board .
waiting to see replys
thanks to all again
29-10-2006, 02:16 PM
Had the same problem sometime back...just took out the RAM module and inserted it again. That solved it
29-10-2006, 03:06 PM
ys.
i already tried.i removed the ram frm the slot and put in the other one.
still thr same problm
29-10-2006, 08:22 PM
try inserting in a different slot, if you haven't done that already...
It could also have been Battery problem or as some other friends suggested, ur mobo have gone kaput
30-10-2006, 09:43 AM
Come get Some
they are called capacitors/condencers
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
01-11-2006, 01:54 PM
SymbianGeek
Why not check the BIOS battery?
--eminemence.
01-11-2006, 04:28 PM
a_g = JPKN
thanks for correcting me.
@mobileman, did you check the Capacitors/Condencers???????, which are around the Processor
