Old 24-10-2006, 01:42 PM   #1 (permalink)
rohus24's Avatar
Default MOnitor problem!
hi guys
i currently own a lcd monitor
whenever i on the comp its output is green in colour during booting stage.
when the xp welcome page comes the screen becomes very bright.
i correct it temporarily by resetting it frm the osd
but when starting a game or switching the monitor on again the same problem persists.is there ne problem with the monitor?
ihave also heard that lcds dont spoil easily.
plzzzz help
thnx
rohus24 is offline
Old 24-10-2006, 01:53 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: MOnitor problem!
I am assuming that u have intel chip set. There might me problems in the video drivers. Just update ur video drivers. Intel releases its chip updates regularly. If that doesnot work out, check out the OSD settings in the monitor. Go through the manual.
Kiran Kumar R
Kiran.dks is offline
Old 24-10-2006, 05:16 PM   #3 (permalink)
rohus24's Avatar
na it doesnt work
i even took the monitor 2 my friends place but there also it shows the same symptoms
rohus24 is offline
Old 24-10-2006, 05:19 PM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
OK...Time to buy a new monitor
rakeshishere is offline
Old 25-10-2006, 06:26 AM   #5 (permalink)
Kiran.dks's Avatar
Oops! Then the problem is the monitor itself. Take it to the service center. Give complaints and if you are with in warranty period, u may save few bucks!
Kiran Kumar R
Old 25-10-2006, 10:40 AM   #6 (permalink)
rohus24's Avatar
ill try that
thnx
rohus24 is offline
