Old 24-10-2006, 01:22 PM   #1 (permalink)
rohus24's Avatar
Default PLz help me in finding a gud amd motherboard
hi guys
im rohit.i wanna buy a amd processor and motherboard
cud u plz suggest me 1
well i want it in the athlon 64 series (processor)
and a motherboard based on via chipset(preferably asus and gigabyte)
im not much into games but want a little gud onboard memory
lastly it shud have least maintenance and gud performace.
if possible also tell me the prices of dem.
i also wanna buy a gud ddr2 ram for it.plz suggest for the same and the price
thnxxx very much.
(its a little urgent so plz help)
rohus24 is offline
Old 24-10-2006, 10:09 PM   #2 (permalink)
Aniruddh's Avatar
Smile Re: PLz help me in finding a gud amd motherboard
Rohus tell us bout ur budget,u gonna play games etc etc...in detial...buddy goin for AM2 wid ddr2 at dis point of time is not a very wise decision as very soon AMD64 939,AM2 processors will b discontinued as far as i kno.. but still if u want then its ur wish.
Aniruddh is offline
Old 24-10-2006, 10:12 PM   #3 (permalink)
Default Re: PLz help me in finding a gud amd motherboard
get C2D unless your budget is sub 10k or so for CPU + MB combined.
akshayt is offline
Old 25-10-2006, 10:41 AM   #4 (permalink)
rohus24's Avatar
okie thnx ill go for c2d
rohus24 is offline
Old 25-10-2006, 10:49 AM   #5 (permalink)
aquamatrix's Avatar
whats ur budget???
for c2d + mobo prices can range from 13k- 30k
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 25-10-2006, 06:16 PM   #6 (permalink)
rohus24's Avatar
well i can extend it upto 9-9.5 k
rohus24 is offline
Old 25-10-2006, 08:16 PM   #7 (permalink)
Then forget C2D. The lowest processor alone costs 8.5k.
If your budget is strictly less than 10k get,
Athlon64 X2 3600+ AM2 Rs. 6600
Asus M2V-TVM Rs. 3400
drvarunmehta is offline
