Old 23-10-2006, 04:23 AM   #1 (permalink)
d
Default 7.1 Audio for Computer
Hey!
I've got myself a creative Inspire t7900 + the DDTS100 Dolby decoder from creative. I've used the optical cable to connect my computer's audio out to the decoder and i do get sound, but the sound's very minimal from the rear speakers even though i've set my decoder and speakers to upmix to 7.1 .. why would that be? should i use the analog inputs perhaps? my motherboard outputs 8.1 sound. or does it make a difference when i use the co-ax SP/DIF?
The torquemaster rules.
d is offline
Old 23-10-2006, 04:54 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: 7.1 Audio for Computer
What Motherboard r u using ?
techtronic is offline
Old 23-10-2006, 09:51 AM   #3 (permalink)
NikhilVerma's Avatar
I think this is the case with all of them ... if you want same sound in all speakers then either use FFDshow and user it's "Mixer" setting ...
or decrease the sound of your front speakers and pump up the overall sound of your system and you will get the same levels of sound.
NikhilVerma is offline
Old 23-10-2006, 01:02 PM   #4 (permalink)
d
my motherboard's a Asus K8N ..
d is offline
Old 23-10-2006, 08:08 PM   #5 (permalink)
I have the same mobo ...
I think all the rear speakers are designed to give low volume when you play 2 channel files like mp3 ... try playing some DVD movie ... and then check if the sound at the rear speakers is loud enough or not ...
