Please suggest a good smps (400W +) for my pc , don't want ultra high
quality like the antecs or coolermasters as they are too costly for me,
also should not be too cheap like the ones bundled with cabinets.
My budget is around Rs. 1000 (maybe a little more).
Regards
Hirak
I just bought POWER SAFE 400watts 1month ago for Rs.1700 in Borivili-Mumbai but in Lamington Road it is Rs.1500 now. According to me It's a really good SMPS for that price...It has 2 very good powerful exhaust fans.
This is a fake (i think) corsit power supply in the market, which is cool, its a 450 watt SMPS with 25amps across +12v....yeah! you read it right. 25amps....it seems to be a gr8 deal for 1.3k....
Powersafe is also one of the good ones in the market..
Look at the COLORSit model M-400U (the last one) here: http://www.colors-it.com.cn/03_produ...n_id_search=21. Me using this one and very satisfied. If u can get a POWERSAFE PSU within your budget, then go for it.
Regards
Hirak
Powersafe is really good. Been using it. Very sturdy with good airflow. Its little out of your budget, but trust me a good PSU is worth investing.
The ColorSit PSU does have 1 (one) SATA power connector.
