Old 22-10-2006, 11:40 AM   #1 (permalink)
Default RAM health
Even though i have 512MB RAM (2 * 256), on system information the available memory shows as 220MB only..is this normal or one of the modules has conked off? is there any tool available to address this?
tech_lover is offline
Old 22-10-2006, 12:15 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: RAM health
Try using only one module one time and start ur pc and check if it works.....and u will teh answer...btw do u haev any onboard graphics card on ur PC???
wizrulz is offline
