Old 22-10-2006, 11:38 AM   #1 (permalink)
Default Can I change laptop screen resolution repeatedly?
Can I change laptop screen resolution repeatedly between 800*600 and 1024*768 almost thrice a day? will it harm the screen?
thanks
tech_lover is offline
Old 22-10-2006, 12:34 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Can I change laptop screen resolution repeatedly?
No, but LCDs are best in their native resolutions only. Other than the viewing pleasure, there are no issues.
Sourabh is offline
Old 22-10-2006, 01:36 PM   #3 (permalink)
tuxfan's Avatar
IMO, it is not advisable to do this repeatedly. If there are certain things that you need to look at a particular resolution, resize the windows. Use on-screen rulers. They will be more convenient. I use JRuler to check web-pages at various resolutions.
tuxfan is offline
