Originally Posted by drvarunmehta
Mobo's based on the 945 and 965 chipset both have onboard graphics.
I'd suggest you take the MSI 965 mobo for about 6.5k if you're not buying a seperate graphics card. The onboard graphics are better than the 945 mobo's onboard.
As for the HDD,
200 GB for Rs. 3800
250 GB for Rs. 4050
300 GB for Rs. 4850
Decide according to your budget.
For the DVD writer get Liteon or Sony or Benq but don't ever get Samsung.
Final config:
Core 2 Duo E6300 Rs. 9000
MSI 965 Rs. 6500
1 GB DDR2 RAM Rs. 4800
250 GB SATA2 HDD Rs. 4850
Liteon DVD writer Rs. 2000
Cabinet+400W PSU Rs. 1500
TV tuner of your choice Rs. 2000
Total Rs. 30,650
Good Config given by drvarunmehta...unfortunately you will not get that config in Hyderabad for below Rs.30000...it will cost Rs.40000+ ... why?...because...I grew up in Hyderabad & also visit that place several times a year...I can gaurantee anyone who contridicts otherwise that it is NOT POSSIBLE to get the above config for Rs.30000 in Hyderabad.
For Rs.30000 you can only get the following config in Hyderabad or even in Secunderabad (as it's a bit more cheaper in secunderabad)
D805 processor (the so called "fake dual core" with D101Ggc = Rs.12000
HDD 200 GB (Samsung or seagate) Rs.4500
2 sticks of 512mb DDR 400Mhz RAM = Rs.7000
or
1 stick of 1GB DDR 400Mhz RAM = 6200
Lite-in DVD Writer Rs.2700
Cabinet & powersupply = Rs.1500 (which a COMPLETE compromise)
I suggest...a cabinet of any decent make = Rs.1500 ...because of the Hyderabad Summer which goes above 40degree) & Powersupply (NEVER compromise) Powersafe 400watts = Rs.2000
Pinnacle 110i TV Tuner card = Rs.2800
Graphics card (OPTIONAL as the onboard graphics for the above config will give you 128mb shared memory for graphics when you have 1GB sys memory)GeForce XFX 7300LE = Rs.3000
Even with this low end entry level so called "fake dual core" processor based config (WITHOUT a good cabinet & powersupply & Graphics card) it will set you back by Rs.30000+... because of taxes...as I've not included the taxes here.
If you are looking for a Core 2 based config you HAVE stretch your budget to Rs.40000 in Hyderabad.
