19-10-2006, 07:14 AM
Price of APC UPS battery
Can anyone please tell me what is the price of a APC UPS battery? The model is "BACK-UPS ES 500"
Thanks.
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
19-10-2006, 09:43 AM
Re: Price of APC UPS battery
It costs 2000 in Chennai...
23-10-2006, 12:08 PM
Thanks.
Go to this page on APC and click on "Chat with a Support Agent" .... you should get the info you want ....
http://www.apc.com/support/index.cfm
23-10-2006, 11:14 PM
But an APC 500 VA UPS itself costs Rs.2000/or even less!
V.Prem Kumar
23-10-2006, 11:17 PM
it costs around 2200 in coimbatore .....
24-10-2006, 12:59 AM
planning to get a 1.5 KV Apc Ups ... how much does it cost ?
25-10-2006, 12:54 AM
?Thanks.
I just bought the same UPS in SEPTEMBER2006 for Rs.2000 in mumbai...u may want to add Rs.200 more for assam...it's a very good ups worth every pisa u spend on it.
25-10-2006, 08:11 AM
But he was askig for the the price of a APC "UPS battery" and not that of the UPS itself!
V.Prem Kumar
25-10-2006, 09:35 AM
APC does not manufature batteries, if the warranty has expired on ur UPS than u can put in any good quality battery which costs Rs.600
25-10-2006, 02:26 PM
Come get Some
buy an excide battery. u'll get it for about Rs. 440
25-10-2006, 07:39 PM
Yes, for almost all UPSs, such a standard 12V, 7AH or 7.5AH SMF battery will do which will cost > Rs.500/-. But I am not sure whether APC uses the same format, voltage and AH rating. Espeially since I happened to see APC Battery listed at Rs.2820 at computerwarehousepricelist.com.
V.Prem Kumar
27-10-2006, 10:21 AM
I from one from APC regional office in PUNE for my Back-UPS AVR 5 0 0 for Rs.800 only.
27-10-2006, 02:32 PM
It seems realistic and reasonable.
V.Prem Kumar
27-10-2006, 02:40 PM
Come get Some
what's the brand of the battery???
27-10-2006, 06:12 PM
Exide i guess dont remember though
27-10-2006, 06:28 PM
Hey i found a Sukam battery for rs. 450/- . The dealer said that the Sukam battery was authorised by APC.
28-10-2006, 03:06 PM
Come get Some
They are chargin hell lot of money for that
add 100 to that and get two Decent Branded Battery
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
28-10-2006, 08:51 PM
The question still remains, whether the standard 7AH 12V battery suits APC?
V.Prem Kumar
28-10-2006, 08:58 PM
#19 (permalink)
"The Cake is a Lie!!"
Removing the Battery is Easy, Remove it, Take it to a Battery Shop, and ask for a "Replacement" or Something.. Pay for It, Come Home, Fix it to UPS, and Voila!
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
30-10-2006, 12:21 PM
#20 (permalink)
Come get Some
well these things are printed on every battery.
what's Printed on your old APC Battery? Stick to it.
30-10-2006, 12:44 PM
#21 (permalink)
My thoughts exactly also buy from APC only IF the warranty of the UPS is still on but the warranty of the battery has expired (APC tends to give warranty like that...I know that coz I got 1 year warranty for battery but 2 years for the UPS I bought from APC last month). But if your warranty of the UPS has already expired than go in for any decent battery.
10-09-2008, 06:00 PM
#22 (permalink)
Hello,
I am a techie guy. Let me tell you the about the rating.
You can go for an Exide or any brand.
The ratings should be as
The terminal voltage should be 12V ---- this is strict.
Next the ---> what is AH. This determines your backup time. More the AH value, more is your backup time.
In AH the A denotes current in Ampere and H is the time in Hours.
For example 7 AH capacity means
Current @1 ampere can be drawn from the battery for 7 hours after full charge.
hence when the value increases, the backup time increases.
Also, Don't go for a batt with very low AH. The backup time will be too low and also the battery dies off easily.
Hence what you need to check is the terminal voltage 12V. You can go for any brand.
However, for UPSs you need a sealed lead battery.
Thank you.
Presoon John
10-09-2008, 08:08 PM
#23 (permalink)
12V 7AH is most easily available but 7.5AH is also common. (Exide, Amco etc.) 7.5AH will give a bit more back up.
V.Prem Kumar
