Old 18-10-2006, 02:04 PM   #1 (permalink)
ThE oNE & ONlY ??
mikeon's Avatar
Default Monitor Trouble !
Hey everyone
My monitor has been giving me some trouble. Sometimes if the table shakes a bit, the image on the screen reduces to a quarter of the screen size. If I just shake the monitor a bit it returns to normal. It feels like the picture tube inside is loose I dont know. Could you give me an explanation for this ??
My monitor is a LG 700E Crt monitor
Holla
R.I.P 2pac, Biggie & Proof
Holla atcha' wherever you are !!!
mikeon is offline
Old 23-10-2006, 03:23 PM   #2 (permalink)
Default Re: Monitor Trouble !
This is normal, never move monitor while its on.
And if it get disorted then use degauss instead of shaking !
Ricky is offline
Old 23-10-2006, 10:22 PM   #3 (permalink)
Fahd.Malik's Avatar
Blur image on monitor can occur on shaking the table when there is a problem in the power supply cord or the cord that is joined to Mobo.
just keep the table still and try to move the wire n check if the problem is because of that.
Cheers
Fahd.Malik is offline
Old 23-10-2006, 11:19 PM   #4 (permalink)
Originally Posted by mikeon
Hey everyone
Holla
Same is the case with my LG 775FT. In the beginning a small knock was enough. Anyway I shifted to LCD.
BTW it served me well for nearly 7 years without any problem.
V.Prem Kumar
janitha is offline
Old 23-10-2006, 11:25 PM   #5 (permalink)
:-o
aakash_mishra's Avatar
@mikeon
How old your moniter is?????????
yaar I am also using the same moniter but never faced such problem
www.amiable.in
aakash_mishra is offline
