hi friends i have Pinnacle PCTV PRO the problem is whenever i start it the sound of WAVE/MP3 and LINE-IN gets low automatically in sound control can anyone pls tell me what is the problem my sound card is Creative 5.1 sound blaster i am using Windows XP Sp2 pls reply fast
The following patch works with PCTV Stereo. Try this with your PRO card:
Pinnacle_PCTV_5.90 AudioLevel Control Patch 26/10/2005
This patch for Vision 5.9 fixes a problem concerning Audio level control that might occur on systems based on chipsets with Intel® High Definition Audio. If you have not encountered any problems with adjusting the Audio level via remote control, it is not necessary to install this patch.
